E-Class (W211) 2003-2009
3 break light stop working estate
Old Nov 18, 2019 | 04:34 AM
Syfy's Avatar
Mercedes S211 E class 320cdi estate
Hi,
My 3rd break light has stop working, had message on the dash, can't find a fuse for it, seen lots of broken wire on the 4 door boot models but nothing on the 5 door estate, has anyone else had a problem with the estate, any help much appreciated.
Thanks Simon
Old Nov 18, 2019 | 06:01 AM
05w211wagon's Avatar
2005 e500 w211 wagon
I have an 05 estate and nothing that i can think of. Have you pulled the bulb(s) to see if the filament has been broken? Start simple
Old Nov 18, 2019 | 07:05 AM
konigstiger's Avatar
'71 Pinto
Check rear SAM connection, wiring in cable guide hoses, inspect wiring/connection/stop lamp. You do not mention model year so I attached all relevant if replacement needed, need VIN if you want part #.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
