E-Class (W211) 2003-2009
Replace rear differential ? What fit in ?
Old Apr 27, 2020 | 09:43 AM
Bermo's Avatar
E320 2003
Hi guys, i just bought e320 2003 and im sure the rear differential have been changed. I've got studs on it and the wheels nuts are bigger 19' in the back and 17' in the front. I never saw before a Mercedes with studs hub.
What do you think the differential is ? Which differential can be fit on those car ?
Old Apr 27, 2020 | 10:26 AM
konigstiger's Avatar
'71 Pinto
Non 4matic rear differential shop part # 2113509614 (1:3.07)
Old Apr 27, 2020 | 10:37 AM
Andre91's Avatar
2012 E350 4Matic
There are stud kits available to fit the factory hubs, it doesn't necessarily mean the diff or axles have been changed. The hub is separate from the axles, anyways. Some people who frequently remove their wheels (for racing purposes or swapping between summer and winter sets) install studs for ease of installation, particularly if they have multiple sets of wheels that would require different length lug bolts. Studs and an open nut allow them to only need one set of fasteners.
Old Apr 27, 2020 | 05:32 PM
Bermo's Avatar
E320 2003
Thank you guys i will look forward to see if its just a studs kit or if the differential have been changed !
but for what you know is there an order differential that can been fit on ?
Old May 3, 2020 | 10:29 PM
syspklc53's Avatar
16 Acura RDX 128k mi 2013 MB E550 4M 124mi
konigstiger
I have a E550 4Matic do I need to change my differential oil and if I do what's the interval?
I saw in the owners man only AMG's require changing diff oil every 2 yrs
Old May 4, 2020 | 09:16 AM
ps2cho's Avatar
E
Originally Posted by syspklc53
konigstiger
don’t threadjack - make a new thread
Old May 4, 2020 | 10:28 AM
'71 Pinto
konigstiger I have a E550 4Matic do I need to change my differential oil and if I do what's the interval? I saw in the owners man only AMG's require changing diff oil every 2 yrs
Psycho is right but I’ll give you a pass this time 2013 e5504m not an MB requirement but proactively same as transmission every 70,000 miles / 7 years whichever comes first.
