Oil cooler gasket
I’m wondering what else I should be considering taking care of while I’m in there. I did a new belt and all new pulleys/ tensioner last year. I’m seeing some wetness around the cam sensor/actuator on the passenger side, and a lot of sooty build up near the intake flap mechanism.
https://parts.mercedesbenzofwappinge...ket-2721840280
https://parts.mercedesbenzofwappinge...ket-2721840080
correct two gaskets. Did mine 2 years ago and still holding up well.
Harmonic Balancer? Doubt it. Never heard of anybody needing one on the 211 chassis. Just make sure there’s no rubber wear on the back and no wobble while running.
I did do a thermostat 40k miles ago but it wasn’t a Genuine Mercedes part.
I’m seeing a bit of weeping at the cam sensors. Is there a specific part, or do I find some generic o-rings? The magnets look accessible with the cooler in place. Is that not the case?
Got both oil gaskets done, put in 4 new cam magnets, replaced 4 cam sensor o-rings, and filled all the fluids.
Unfortunately, the lower idler pulley and the pulley on the tensioner are wobbly despite replacing them last year. I ordered those and a new belt. Won’t know if I have any leaks until I install those and test drive it.
