E-Class (W211) 2003-2009
Ligts adjustment, is it possible?
Old May 15, 2020 | 12:33 PM
Kaha2007's Avatar
w211 200cdi 207 sedan
Hei, I have a problem with halogen, long beam, I am not sure, if that's a correct name but hope, you know what I mean
​​​​​​I have H7 bulb there. Problem is, that it's pointing in the sky, really high
Is it possible to adjust it?
My car is 2007 W211, sedan
Old May 15, 2020 | 12:43 PM
Eddy001's Avatar
Mercedes E class w211 T-model
Hi,yes on the headlight himself there is two adjustments sideways and up,down,once you open the bonnet is at the top facing the bonnet,use a screwdriver and you can adjust.
see here
Old May 15, 2020 | 01:49 PM
Kaha2007's Avatar
see here
https://www.youtube.com/watch?v=9qIzHY6XI3Q
Thank you! I will try that today evening I hope, if not, tomorrow. Hope it will help, driving at night, disaster!
There's one thing, that bothers me. In the video, he adjusts regular lights, but mine, are fine, only one, of this extra, for driving at night in empty roads, is pointing up. If I start adjusting, won't it make regular light lower than it should?
Old May 15, 2020 | 02:10 PM
Eddy001's Avatar
OK no problem, here my channel it will help in the future as i am always posting useful w211 videos, subscribe to be notify when i post a new video.
https://www.youtube.com/channel/UClM...K23atDXux1qHpw
Cheers
Old May 15, 2020 | 03:29 PM
Kaha2007's Avatar
Cheers
Awesome! I'm sure, I will use it in the future, I just bought that car but still, if I start turning that screw, won't I change main light? I need only high beam to be lowered...
Old May 15, 2020 | 03:32 PM
Eddy001's Avatar
are you sure the bulb is not upside down?
once append to me on a clk 230 the high beam bulb was wrongly installed
Old May 15, 2020 | 03:51 PM
Kaha2007's Avatar
That's H7 bulb, can you do it upside down? I took it out, I heard about that it could bo placed wrong, but it didn't seem like it...
Old May 15, 2020 | 03:55 PM
Eddy001's Avatar
hummmm, strange one
Old May 15, 2020 | 03:59 PM
Kaha2007's Avatar
hummmm, strange one
​​​​​ and now, you made me worried.. .)
Old May 15, 2020 | 04:01 PM
Eddy001's Avatar
You can easily check if the bulb is ok
check here how to do it
Old May 15, 2020 | 04:07 PM
Kaha2007's Avatar
I can change it, no problem, but bulb could do that?
Means, I understood it correct, adjusting screw, doesn't work with that type of light? Only with main, road ligts, other should be adjust as well, in the same time, when turning the screw?
Old May 15, 2020 | 04:15 PM
Eddy001's Avatar
That screw is to adjust main lights up and down, or right,left, each headlight has the screw to adjust, unless the mechanism on the headlight is damage
Old May 15, 2020 | 04:20 PM
Kaha2007's Avatar
Looks like, I need to change whole thing..?
Old May 15, 2020 | 04:24 PM
Eddy001's Avatar
I don,t know if can be repair, and is only an assumption that is damage, by only checking closely can see if really not working.
Old May 15, 2020 | 04:28 PM
Kaha2007's Avatar
I know, there was tiny crash, bumper was changed, but it can't be body problem, because main light is correct. It has to be sth inside, that's broken? Sorry, for weird questions, but I'm not an expert, at all, learning now
Old May 15, 2020 | 04:32 PM
Eddy001's Avatar
if i was next to it i would find why, not been there is difficult to diagnose
Old May 15, 2020 | 05:04 PM
Kaha2007's Avatar
Thanks for advices!
