- Mercedes Benz E Class Why is My Suspension Bouncy?
Guide to diagnose trouble and recommended solutions
E320 suspension - I don't get it. Rough.
I've adjusted tire pressure from 29psi up to 40psi all the way around. Regardless, this car is very jarring over medium to large bumps in the road. When cornering, if ONE wheel hits a bump, the entire front end skirts to the side. So much for independant suspension.
Are they trying to compete with BMW by transfering more bumps to the cabin? The real trick is to communicate the little stuff yet soften the blow of medium and larger bumps. Somehow, Mercedes managed to hide the small stuff completely, make the car hop sideways in a corner over medium or larger bumps, and make large bumps very rough, and yet STILL have the thing float around up and down like a Cadilac!
I love the car, but the suspension tuning could have been done by a Kindergarten class (with no stated objective).
So far, I'm happiest with higher pressure (at 36.5psi today). At least it doesn't float as much. The bumps are jarring regardless of pressure.
I used to drive a 330i with sport suspension with Pole Position S-03 tires at 37+ psi, so don't classify me as a wussy who can't handle feedback. This is flat out poor tuning. I'm sure we have some marketing morons to thank for it.
The 5 series with sport suspension is far superior in this regard. More firm, yet less jarring. If it weren't for the stiff runflat tires, it would probably be perfect.
Comments?
Any idea why the car rides fairly rough? Would different bushings make a difference?
Is the suspension aluminum like the E60, or is it steel?
I would think with 16 inch wheels, the unsprung weight would be very reasonable. Wouldn't that make tuning out the bumps very easy?
Maybe Mercedes customers of old are expecting a certain road feel and they tried to preserve that. To me, the suspension feels dated by a minimum of 20 years.
What tires are you running and where do you live?
I've had the opportunity to make a BMW/M-B comparison, too. Our previous car was a '97 (E39) 5-Series. The folks in Munich are as brilliant at tuning suspensions as the people in Stuttgart are clueless. Our E39 was a remarkable combination of supple and quiet ride and tack-sharp handling.
I can't stand the exterior or interior of the current 5-Series, so I'm seriously considering going downmarket to an Acura TL or Infiniti G35.
My E320 certainly doesn't behave like yours, I find it the nicest riding car I've driven for a long time, and the handling is quite acceptable given what it is trying to achieve.
Comments?
The "new" E-class has a reasonably smooth ride, but I do agree, it could be better and its leaning too much on the firm side. However,the chassis feels very rigid and strong, and there's no booming noises, and a lot less road noise compared with the W210. The E-class does have capable handling though.
PS--If you really want a smooth and quiet ride (but with no handling capabilities), get a Lexus LS 430 :p
I think the W211 rides rougher than an E39 with sport package. The E39 let the little stuff through (surface texture), but not the bigger stuff. The ride of the W211 makes it feel heavier than it is, and maybe that was their goal
My car doesn't feel floaty with the tire pressure at the current 36.5psi. It did when I went 29 all the way around. I realize that this is lower than MB suggests for the rear.
I also find the car to be surprisingly noisy over textured pavement. I suspect the tires are a major contributor (neither of the stock tires were well reviewed at tirerack). I also wonder if having tinted windows (and therefore the inside rubber seals rubber replaced with fuzzy felt stuff) might contribute also.
Like I said, I love the car. I did ride in a 10 year old Lexus ES300 that was quieter and less bumpy though. I'd expect more for a car in this class.
The ride / noise level in the city is a bit higher than I would have liked.
The car just feels better at speed. In the city I find the steering ratio to be impossibly slow - at speed it feels just fine.
In the city I think the throttle response / transmission response can be funky. At speed - no problem.
In the city - I think the brake "feel" is awful. At speed - the brakes are excellent.
Obiviously it would be nice if you specify which brand, model, and size of tire you have when reporting handling and ride issues.
Thanks,
David
Good point. The car may be optimized for higher speeds. Hadn't thought about that.
I do agree steering is a little slow around town, but I drive this car slower than I drove my 330i, so I guess it doesn't bother me much.
FYI, I believe my tires are Michelin MXV4 Plus or something like that.
Comments?
I bet you the S Class has a way more smoother suspension, and the CL over the SL.
drive me nuts too....many times i've let go the steering wheel only to realize i gotta "unturn" it.
It is my understanding (which may be wrong) that low frequency shock stiffness affects handling over low frequency bumps and through corners, and high frequency stiffness affects ride over sharper bumps like railroad track, expansion joints, and potholes.
In earlier times shocks got stiffer at higher frequency, creating a loose floating feeling while still banging into bumps. Digressive shocks do just the opposite, providing firm control over body movement while being relatively soft over high frequency bumps.
It sounds like a shock problem...IMHO.
