Wont Shift Gears (Fault Codes Inside)
- the car would not shift gears (Once I came to a stop, it would not shift past first gear).
- Would not shift past neutral (until I turned the car off)
- Occasionally would not show (Drive Mode and Sport/Comfort on the cluster (D XXX,XXX S))
Codes:
- Generic Code: P0705
- MIL & Stored: 2226-1, 7209
- Stored: P240-C, P1856
I let the car sit for 2 days, cleared all codes, and it seems to be working fine for the 10 Miles I drove it today, and no codes are stored or pending. HOWEVER, I want to replace the part that was responsible for this as preventative maintenance.
As a side note, during inspection for possible damage, I did unplug the TCM without the car being on, but this may have triggered 7209. (Of course, I plugged it back in before scanning the car.)
Any Clues?
\SOLVED!
- Cleared codes & received these back again "2226-1, P1856, P240-C" same symptoms.
- Another forum had the same codes and it ended up being the ESM (Electronic Shift Module).
- I replaced my ESM with a used one "Same part number of course" and cleared the codes. So far, 3 days / 100 miles in, and the problem has not returned.
I will make an update if the problem returns.
Note: 7209 code is not relevant as mentioned in the Original Post, as this was triggered by me disconnecting the TCU. This code never came back after clearing codes.
Hope this helps.
Hope this helps.
Edit: Problem returned as soon as I left the driveway.
P.S. 2006 Mercedes E320 CDI 200,000 Miles.
I did replace the conductor plate last year (the thing that looks like a connector plug on the transmission).
Peter
Does the new version still lock on with a snap ring or is the snap ring part of the bushing?
Thank you,
Peter
FWIW,
Peter
It's literally your shifter.
My problem has not returned, knock on wood.
Sounds like I need to remove my shifter to get the #, right? I wonder if I can undo everything except the Shift linkage and see the ECM? Damn! I had the old shifter on my bench for several months and if I looked at the bottom, I never realized the ECM was on the there! Naturally, I got tired of moving it around and late last week I finally threw it away!
But you have told me where I can look in the parts manual - Thanks again +
sorry - I failed to take my time and understand what you are saying. You said the ECM is the Shifter which I already replaced - Oops -
2006 Mercedes E350AWD
Maybe you can tell if there is anything unusual or odd about this VIN - I've had 5 or 6 MBs over the years and never saw one with an X in the VIN?
Thx
LT
Thanks again for the info.
