Steering Wheel Frahm... or not
Picked up this steering wheel that had a weight / mass in the middle that appears to be some sort of Frahm. No electronics. Nothing but a metal weight suspended by the green silicon plugs. Has a plastic cover I assume to prevent the airbag wires from rubbing on it. Anyone have any idea of part number or true function? Is it something I should put on my E350 to take out steering wheel vibration, not that I have any anyway? I have seen it in other pictures but with no reference to it. Thanks in advance.
All the other steering wheels I have purchased and my original steering wheels had the same 3-hole mounting pattern for this thing but none of them had it installed.
To quote a famous commercial, "It's a mind boggling thing."
Received 4,435 Likes
'71 Pinto
Thought it had to do with CU but looks like air bag mount notice routing sleeve at top for airbag harness. Reverse side of airbag:
The little groove in the black plastic cover is for that harness jumper (between bag and controller) to ride in. The controller is the silver box in the first picture and is suspended between two pieces of the steering wheel rubber. This thing doesn't touch the controller or airbag.
The more I look on eWay the more I see steering wheels with this thing but can't tell rhyme or reason on what does or doesn't call for its installation. Also don't see anyone selling it separately from the wheel. It is just funny that I hadn't seen one before in any of the ones I bought or in my own personal cars. Most likely it is a model / option specific thing. Just trying to solve the mystery.
Received 1,488 Likes
This place is a joke.
Damn I'm good. That part number fits E-class models 211.020 211.022 211.024 and 211.222 which are all diesel versions; E280 CDI, E320 CDI, E300 BLUETEC, E320 BLUETEC
As I surmised before, it's for vibration control in diesel models. I asked if you were outside the U.S. because some of those models are not U.S. spec cars.
You're welcome!
You're welcome!
You're welcome!
You're welcome!
Anyone have a diesel that needs the Frahm weight in their steering wheel?
E55Greasemonkey (02-05-2021)
'71 Pinto
Confirmation, so you can sleep tonight
