2004 E320 Subwoofer Help
Me:04 E320 Pewter:Wife:04 E320 White
Have the HK system...not much base with the system even when turned all the way up...want to do something simple to improve.
Install sub in box in trunk...would like to simply disconnect existing wires to the stock pancake sub and plug them into the new box that I would put in the trunk...can someone tell me the easiest place to access these wires and what they look like...will the stock amp handle a 400 watt sub?
Thanks to everyone...
Not sure if you've seen this thread before
https://mbworld.org/forums/e-class-w211/73039-upgrading-sound-system-e-class.html
But it might give you some ideas on how to improve your sound.
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
You may want to use the search function of the forums when you're looking for information... a lot of this has been covered and you might get some good ideas.
-s-
