E-Class (W211) 2003-2009
Command Unit Software Update
Old Apr 9, 2021 | 09:22 AM
joebudd's Avatar
E320
Vehicle is a 2007 E320 Bluetec. I want to update the radio software. I find and read so much conflicting material. I did a search on this site and found a thread with a link right to MB with all the material needed for the update. One of my questions is how do I tell what version is on my unit? Is there a link for Mercedes for the Navigation DVD as well?
Thank you
Old Apr 9, 2021 | 01:03 PM
gogydm's Avatar
08 E350
Do this and see what version you currently have.
The latest version for the navigation DVD is v15 2015-2016. Update your COMMAND software and if you can't find the nav DVD send me a PM.
Old Apr 9, 2021 | 04:11 PM
joebudd's Avatar
E320
Here is what is in the car and the file I want to install. How do I tell if the car version is older?
Old Apr 9, 2021 | 07:43 PM
gogydm's Avatar
08 E350
The file you are trying to install is for firmware 30/06 which is definitely older than what you currently have. It seems like 30/06 was released only for the EU COMAND, which is different than the US one and firmware is not compatible. What you should be installing is 29/08 (though I think it shows as 28/08 when you do a version check on the COMAND after you perform the update). Here is the information on it: PDF The PDF contains information on how to perform the update. Here is the update itself that will need to be burned on a CD. ISO
Let me know how it goes
Old Apr 9, 2021 | 10:03 PM
joebudd's Avatar
E320
I hate to keep bothering you with questions. But after reading the pdf file it states updating the Audio Gateway (AGW). Do I have to worry about that?
Old Apr 9, 2021 | 10:31 PM
gogydm's Avatar
08 E350
Don't worry, that's what the forum is for. You shouldn't have an issue with that since you have an 2007 car and are most likely running that or a newer version. I've updated an early 07 model with no issues with the AGW. Even if something happens the dealer or indy with the correct tools can flash the AGW.
PS Try playing an audio CD in the COMAND unit CD drive to make sure it still reads as it should.
Old Apr 10, 2021 | 03:32 PM
joebudd's Avatar
E320
Ok. I burned that file on a CD. I then looked to make sure all the files were on the disc. Looked good. I put an audio disc in the command unit, it played. I then pushed 1,3,8. It told me to insert disc. Command unit told me I was missing a file. Error, click ok, then disc pops out. Any ideas?
Old Apr 10, 2021 | 04:11 PM
gogydm's Avatar
08 E350
What program did you use to burn the ISO file? From your post it sounds like you've burned the ISO file to the CD correctly, with the ISO file extracting on the CD. Also was the COMAND unit empty when you first pressed 1,3,8? I'd also take out the DVD from the trunk unit just to be sure while updating.
Old Apr 10, 2021 | 04:40 PM
joebudd's Avatar
E320
I used nero. The file didn't state it was zipped. After I burned it I left it in the cd drive and looked at the files. It showed like 8 or 10 files. No cd's in the 6 disc changer. The NAV player did have the map disc installed. I will try it again. The cd in the command unit was empty, pushed 1,3,8 and it stated insert update cd. I think I did everything correctly.
Old Apr 10, 2021 | 04:52 PM
joebudd's Avatar
E320
I take that back. Files may have been in a folder. I re-burned the disc. I will try in a few.
Old Apr 10, 2021 | 05:01 PM
gogydm's Avatar
08 E350
If the issues persist, use ImgBurn with the option "burn image to disk" and specifying the ISO location and you should not have any issues. Also make sure to burn at a lower speed for burn quality purposes.
Old Apr 10, 2021 | 05:30 PM
joebudd's Avatar
E320
After I thought about it for a few minutes, the problem was the files were in a folder. All fixed. Now the NAV files and or maps. How does that work?
Old Apr 10, 2021 | 05:38 PM
gogydm's Avatar
08 E350
You have three options:
  1. Original map disk from Mercedes
  2. eBay to purchase either a used disk or a non genuine copy
  3. Download it from the internet
Old Apr 19, 2021 | 05:16 PM
ot1's Avatar
ot1
2006 E320 CDI
i would think that there would be only an .ISO file on a properly burned disc.
Old Nov 24, 2025 | 09:19 AM
W211.'s Avatar
Mercedes Benz E 350 4 Matic 2008 , ML 350 4 Matic 2013
latest iso for w211
Hey, any way you can attach again the newest version of the headunit for update?
