E-Class (W211) 2003-2009
Oil level sensor malfunction
Old Jul 6, 2021 | 09:25 PM
chris1978's Avatar
05 mercedes e320 cdi
Hey guys, I have an 05 e320 cdi that has the above message. I ordered a new sensor and drained and changed the oil and filter and replaced the sensor. The car is still giving me the message just after startup. Anyone have any ideas or experience with this type thing?
Old Jul 7, 2021 | 11:19 AM
tjts1's Avatar
C320
Try resetting the error messages in the ECU.
Old Jul 7, 2021 | 09:16 PM
chris1978's Avatar
Tjts, I recently moved and cannot find my scanner. I am going to go through my shed one more good time and spring for another if I can't find it. This isn't a typical error though. It just pops up as a message and after the car is turned of and started back up there are no messages for like 30 seconds.
Old Jul 8, 2021 | 03:10 AM
chris1978's Avatar
Oh boy, The problem is that the oil pan is now full of coolant. I've been having issues with coolant level decreasing but couldn't find a leak. I went ahead and replaced the original radiator since I had a replacement on hand. Prior to this repair I had the oil level sensor malfunction so I swapped the radiator drained the oil and filter and installed the new sensor and replaced the oil. I filled the system back up with coolant and like my post said I got the malfunction again. I decided to check the oil with my garage dip stick and it was clearly milkshake. When I drained the brand new oil it was full of coolant. What gives? Blown head gasket ya think? What else could cause this on an 05 w211 cdi?
Old Jul 8, 2021 | 07:35 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Oil cooler… very common, though they typically leak externally (oil) due to the gasket aging (hard).
However, since coolant and oil pass thru it wouldn’t be unheard of them mixing.
Old Jul 8, 2021 | 04:07 PM
chris1978's Avatar
BMW power, thanks for your reply. I'll check that out. When I first bought this car about 5 years ago I actually did have an intercooler gasket leak. It allowed oil in the antifreeze. That was a big mess. I replaced the gasket but I didn't replace the cooler. I pray that is all it is. I will pull it off today and inspect it and report back. Thanks again for your reply.
Old Jul 8, 2021 | 09:10 PM
chris1978's Avatar
BMW POWER, I removed the oil cooler. Is there a specific way to determine if the cooler failed? How do I determine if it the intercooler head gasket?
Old Jul 9, 2021 | 01:10 AM
chris1978's Avatar
I kept saying intercooler earlier, I meant oil cooler. I removed the oil cooler and pressurized it under water with the oil ports above water and saw no bubbles. I then filled the oil ports with rubbing alcohol and pressurized it through the coolant port and saw no bubbles. I think the cooler itself is intact. The gasket is only about 4-5 years old and still feels very soft. I am beginning to think it is in fact the head gasket. Is there any other advise?
