4Matic noises when turning
The car is making small "clunking" noises when turning in low speed. The noise reminds me of CV-related issue, but both left and right CV-axle have been replaced. The noise occures each time the wheel rolls a round, but only when im turning too. Besides this I have a heavy vibration when driveline is under load, especially when gear engaged. The vibration also occures heavelly when im parked (or backing up) in a slight incline (engine down) when the pawl in the transmission is stopping the car from rolling (not using parkingbrake). The engine and transmission mount have been changed.
Don`t know if the issues are related to eachother, but let me know if you have any ideas what the issue might be...
Bearing replacement was easy. Bought the bearing at orielys and took the hub to any local auto shop to press out the old bearing and press in the new one. I couldn't press it out myself, the bearing is THICC.
Since you'd have to remove the spindle assembly, it may also be a good idea to replace all the suspension components if they're worn out.
