E-Class (W211) 2003-2009
Do we need to warm up engine in the morning???
Old Sep 18, 2004 | 04:38 AM
lpolo's Avatar
MBenz
Hello, have a quick question here. On new car like W211, do we need to warm up the engine in the morning before driving it out? How long? i heard from some people that new car is no longer need warming up and can just start & go. i am an oldies, all my cars are 1999-2000 and i always do some 5-10mins engine warm up before out.
please let me know.
Old Sep 18, 2004 | 07:09 AM
kort677's Avatar
'05 e320 cdi, '05 lexus rx330
please let me know.
I would not warm it up, however I wouldn't drive it hard for the first few miles either
Old Sep 18, 2004 | 08:05 AM
Oslo's Avatar
please let me know.
No, nay, never!
Old Sep 18, 2004 | 11:09 AM
Barry45RPM's Avatar
2015 ML 350
If it warms up idling, it'll warm up moving. Just just drive it gently 'till the temp indicator moves up about 1/4 way. Warming up a fuel injected car is a waste of gas & time. Carbureted cars had to be warmed up a little because they hardly were driveable when cold.
Old Sep 18, 2004 | 01:23 PM
AMG PWRD's Avatar
1999 C43 AMG - 2003 E320 CDI (W211) AVANTGARDE (located in Portugal)
No need to warm it up in the morning ( just don't floor it for a few miles )
Old Sep 18, 2004 | 01:42 PM
DWP's Avatar
DWP
'08 AM Vantage V8 - '03 E500
Since you're in California, you probably don't have a CDI. A diesel may actually require some warm-up in cold weather - I don't really know - but like the others said, standstill warmups of any other W211 are just a waste of gas. People in The Great Frozen North might justify the practice as an opportunity to warm up the interior of the car and defrost the windows in winter, but that hardly applies in the Bay Area.
Old Sep 18, 2004 | 01:55 PM
glojo's Avatar
E-class E300e Estate, Sprinter (stretched limo)
[QUOTE=DWP]Since you're in California, you probably don't have a CDI. A diesel may actually require some warm-up in cold weather/QUOTE]
Correct the CDI still has a 'Pre-Glow' However even in winter it only takes a few seconds to go out, and then vav - a - vav - a - voom. Or as the philastines amongst us still think 'knock, cadonk, knock'.
Bye for now,
John
Sunny but windy Torquay
Old Sep 18, 2004 | 02:28 PM
Barry45RPM's Avatar
2015 ML 350
Diesels are computer controlled & injected too so they are "good to go" right away too. As they warm up, they will run quieter & smoother. No need to waste that fuel either.
In the old days without computers & injection, when cars were cold, that would not get the exact air fuel mixture when cold, so they would gasp & choke, or run rich & flood, then stall or buck ...thats all gone now. People who began driving in modern times have no idea how crude cars were compared to todays cars. The cheapest cheap car starts & runs better in the middle of the winter than even the best of the best cars of the '60s '70s
Old Sep 18, 2004 | 02:49 PM
glojo's Avatar
Hi Barry
Do you remember that thread you started about the E class Owners Manual?????
Well.............
UK Edition page 45
Vehicles with a diesel engine
Turn the key to position 2 in the ignition lock.
The preglow indicator lamp in the instrument cluster lights up.
As soon as the preglow indicator lamp goes out, turn the key to position 3 in the ignition lock and release it.
The engine starts automatically.
I
You can start the engine without preglow if the engine is warm
Me again, As my old driving instructor used to say, "Once you pass your test you will be develop all sorts of bad habits, try your best to avoid them"
I don't doubt that the engine will start without waiting for the preglow to go out. After all it is only on for a few seconds maximum. I am also sure though Mercedes-Benz would not fit unnecessary technical gizzmo's in their engines if they were not required.
Happy motoring
Regards,
John
Dusk in Torquay
Old Sep 18, 2004 | 04:45 PM
Barry45RPM's Avatar
2015 ML 350
Didn't mean to imply you don't need to use the glow plugs. (Who needs to crank that long!) I meant that once its started you can put it in gear & go without letting the engine "warm up" to normal operating temperature when the heat & compression will make the car smoother & quieter...
(...Dad had an '84 S500 turbo diesel till 2000)
Old Sep 18, 2004 | 04:49 PM
glojo's Avatar
Didn't mean to imply you don't need to use the glow plugs. (Who needs to crank that long!) I meant that once its started you can put it in gear & go.
Hi Barry
Totally agree
Kind regards
John
Bedtime in Torquay
Goodnight
Old Sep 18, 2004 | 09:40 PM
BoSoxFan's Avatar
2004 E500
What you said is so true. I had forgotten about manual chokes until your post. Both my 190SL and MGB had chokes which had to be used with a cold engine and then gradually released as the engine warmed up. Even with the chokes there were some cars, such as Fords, which had to be started 3 or 4 times before they would catch and not stall. Cars really have come a long way.
Old Sep 18, 2004 | 10:05 PM
Barry45RPM's Avatar
2015 ML 350
Remember not being able to pull away from the curb after a cold start without either hearing a "cough & a flood" stall out (unless you could "vibrate" the gas pedal just right)? ...and that hissing sound just before the shudder & restart? Yech!
Todays new drivers have no idea what a bad car is!
Old Sep 19, 2004 | 01:20 AM
Nanky's Avatar
2007 E63, 2007 BMW 335i Coupe & 1991 Honda Accord
please let me know.
5-10 mins is excessive. At first start-up, I am in the habit of waiting for the rev to drop before moving. This is just enough time for me to hook up my phone and buckle up. Again, I do this out of habit. I don't believe it is even necessary. As others have mentioned, refrain from hard driving for the first few miles.
Old Sep 19, 2004 | 01:39 AM
Dema's Avatar
i535
What for to warm up? To get better fuel economy? Indeed it can be helpful.
Old Sep 19, 2004 | 12:37 PM
BoSoxFan's Avatar
2004 E500
And then there were all those little tricks that you would use once you got to know your car: on some, you would never touch the throttle for fear of flooding; on others you pumped it two or three times to the floor before starting; some required a little gas while starting; the amount of choke would depend on the outside temperature. Of course, if you made a mistake on any of those, then you were screwed because it would flood or you'd kill your battery if it was real cold and the battery at all weak. Ah, driving was a true challenge in those days.
Old Sep 19, 2004 | 03:53 PM
johna1's Avatar
17 E220D, 11 E350 CDI(sold), 06 CLS320 CDI (sold), 05 Cadillac DeVille (gone), 04 E320 CDI (sold)
I had Chrysler Valiant with automatic choke. On cold days it would pour fuel into the engine. With the automatic in Drive, it would get up to 45mph, without touching the accelerator!! Driving to work in the morning was all done with the brakes...
Old Sep 20, 2004 | 12:57 AM
rickyfanmdr's Avatar
2003 E320
I get in the car and go. I never warm it up.
