E-Class (W211) 2003-2009
SBC Pump Compatibility
Old Nov 28, 2021 | 05:00 AM
e500slr's Avatar
2011 E63, 2013 CLS63
Hey guys,
I've got an SBC pump in an E320 with part number A0094312512. I found one at a scrap yard with part number A0054319712. I was told that if they are in succession then they're compatible. Are these number compatible and how can one tell?
Old Nov 28, 2021 | 10:04 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
mbepc.net
Old Nov 28, 2021 | 03:02 PM
konigstiger's Avatar
'71 Pinto
Don’t remember if this was discussed but there is a 25 year extended warranty on SBC unit, see attachment. Doesn’t look like 9712 is compatible, different software. If there are no covered damage (fault) codes stored you can request attached recall, if not documented in VMI as completed, be performed. If re-programming fails you are entitled to replacement unit at no cost. Recalls do not expire.
File Type: pdf
File Type: pdf
Old Nov 30, 2021 | 11:28 PM
e500slr's Avatar
Unfortunately we don’t have that recall here in Australia as it’s US only.
what about 72 12, is that compatible with 97 12?
Old Dec 1, 2021 | 09:15 AM
'71 Pinto
Only other unit with code match is 2612.
Old Dec 1, 2021 | 10:48 AM
Red Ryder's Avatar
W211 wagon believer
This is my concern with having a 2004-05 E320. Even if I can take advantage of the warranty, the unit will go bad again (around 100k miles seems typical?) and after the warranty is gone then it's a big expensive problem again. I keep my cars forever so it would be a factor for me.
Or are the revised SBC units fixed and won't have the same issue as the ones under the warranty?
Old Dec 1, 2021 | 11:42 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
>207,000 miles on my car with original SBC unit. The pressure reservoir is reading at the minimum recommended pressure but has not yet triggered any codes. When it does, into the dealer I go.
Old Oct 6, 2022 | 11:29 AM
Ando_305's Avatar
E220 2004
Hi konigstiger
Can you help me out please. I own E220 2004, my car VIN is WDB2112061A509784 and I need a new SBC pump. I found new but I am not sure is it compatible with my car. New SBC pump nr is A0054319712, 0265250111.
Also what pump number should I have on it, not sure if its original SBC pump on my car.
Regards
Ando
Old Oct 6, 2022 | 12:52 PM
'71 Pinto
File Type: pdf
Old Oct 6, 2022 | 02:34 PM
Ando_305's Avatar
E220 2004
Hi
Thank you for your reply.
Just to clarify the part number what I would like to use is A0054319712 not A0054317912 if it matters. I dont know cars that well, so am I able to use that part on my car?
Regards
Ando
Old Oct 6, 2022 | 04:39 PM
'71 Pinto
Part #s posted is what ISPUSA is showing as compatible, 9712 = 230 (M class).
