E-Class (W211) 2003-2009
Transmission number
Old Dec 23, 2021 | 12:37 PM
drchpeteros's Avatar
e350 4matic wagon 2009
Transmission number
2009 MB e350 4matic wagon
Considering DIY transmission fluid and filter change but I don't know what number my transmission is? I see 722.9, 722.6, 722.6xx etc in the threads I've searched, but not sure which mine is. I think it's 722.6xx because when I down shift manually it goes into 4th gear according to the display so it must be a 5 speed, correct? I'd like to find some detailed instructions on the fluid and filter change and have seen several on the 722.9 but not 722.6.
1 - How do I know which transmission I have?
2 - Anyone know of a link to detailed instructions for that transmission?
Old Dec 23, 2021 | 01:40 PM
konigstiger's Avatar
'71 Pinto
722.6 thought this was already asked and answered https://mbworld.org/forums/e-class-w...ml#post5685903 see attachments and pull sheet 236.14 here for ATF: https://bevo.mercedes-benz.com/beam.en.html
Old Dec 23, 2021 | 02:28 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Based on the link the Konigstiger posted, I am glad you realized your Indy was not very well informed on these transmissions. At this point, even if the Indy accepted to do the job, I would not sleep well anyway. So, it is either a DIY or another Indy.
Old Dec 23, 2021 | 06:07 PM
sorry for the repeat
Apologies for the repeat question guys. I actually did search for it in the 211 forum just today but came up dry, and I'm the one who asked the question 8 years ago! I appreciate the pdf's as well. No need to continue this thread.
Old Dec 23, 2021 | 09:51 PM
cetialpha5's Avatar
You can pick up a case of Shell ATF 134 at a Shell distributor. Last time I got it, it was around $60 for a case of 12 quarts which is much cheaper than the $20+ from the dealer. In MA, there's a distributor in Worcester.
https://www.shell.us/business-custom...r-locator.html
