New blower and resistor - still no air flow, what next?
I've thrown as many parts at this problem as I can think of. Could the new resistor be bad? It's not a Behr, Bosch, it's made in Taiwan FWIW. The resistor is getting 12+ volt power and a 9v signal. What more should I be looking into?
Thanks for any help you can provide. Winter with no heat is not fun!
Thanks for the reply. Unfortunately I don't have the old fan anymore, since the new one worked for about two weeks, I threw the old one away. Re. voltage - I have tested and have approx. 11.8v (with car off) at the blower terminal on the fan resistor. Again, when I turn on the HVAC, the fan will spin slowly for about 5 seconds, then stop. Bench testing the fan with a full 12v makes it spin at full speed. I am assuming that means the fan is not the culprit.
It's as if some aspect of the system is not letting the fan get a signal to run continuously. I've followed the Pelican Parts blower motor testing sequence and the last step utilizes a labscope - which I do not have, nor do I know where I can borrow one. https://www.pelicanparts.com/techart...or_Testing.htm
At this point, I'm considering buying another BEHR or similar OE resistor and seeing it it makes a difference. I hate to throw more parts at this problem, but I'm stumped.
A faulty control unit is what the salesperson at FCP Euro suggested. I ordered a used one (new is $1200 at local dealer) and that did not have any effect. The symptoms are the same with my old control unit and the used one I bought.
A sincere thank you for your feedback, I'm stumped so any thoughts are welcome.
As the Pelican Parts blower motor testing procedure suggests, I back probed the plug/connector at the fan resistor with a DVOM. There are 4 wires; the two large gauge ones are power for the fan (one neg, one pos.) the smaller gauge wires are the signal from the HVAC control unit. With the car off I have approx. 11.8 volts on the large positive wire, with the car running its 14+ volts. The signal wire has 9.2 volts with the car running and HVAC turned on. The Pelican parts test procedure says 'about 10v is normal for the signal wire, no matter what speed you have the fan set to' for the signal wire. So I believe I have confirmed that the resistor is getting enough voltage to run the fan, and the correct signal voltage - assuming my 9.2v is equal to "about 10v" in the Pelican test procedure I linked.
I spoke to my Indy and they are going to take a look at the car in a few weeks. I hate to conceded defeat but without the correct system to properly diagnose this I'm stuck. In the meantime, I'm going to start looking for a MB specific system that is not too difficult to use and hopefully won't break the bank.
Thanks to all who took the time to respond. I hope to be able to return the favor some day.
Thanks for your input. I'm trying to run the heat, not A/C. I hadn't thought of the possibility that if the compressor doesn't kick in for whatever reason, the system wouldn't allow air flow. I have been using the "auto" HVAC setting since I've owned the car and when the temps got colder I simply hit the A/C button so as to not run the compressor. *unless it's raining and I need it to dry the air. The A/C worked fine a few months ago when it was still warm enough to use it. I suppose that doesn't really mean anything however, it could have failed and I wouldn't have known.
You raise a good point, I'll mention it to my indy mechanic in a week and a half (earliest I could get the car in). I've done some HVAC and A/C work before on much simpler cars but without the correct diagnostic code reader for MB, I feel I'm in over my head on this one and will pay to have it sorted out. I'll report back once it's fixed in the hopes it helps someone else down the line.
In the meantime, if you had access to a gauge set, it would only take a few minutes to throw gauges on it and rule out a pressure-related fault. Not sure on Benz, but low/high refrigerant won't necessarily throw dash CEL's on a lot of cars, the sensors just shut down the compressor and stuff to prevent damage.
Thanks to all who took the time to post suggestions!
I replaced my squeaking blower motor a little while ago and it would start up no issues. Replaced it with a an OEM Behr from FCP euro but kept my blower motor regulator. Fan started up no problems. Now when I turn on the blower/fan it sometimes doesn't start at all, then waits about a minute or two of driving then starts. Then if I adjust on different fan speeds it sometimes goes up and or down but sometimes doesn't do anything.
I only want to stick with Behr for the regulator but as everyone suggests it's back ordered everywhere... so I guess I can wait....
This is the message I am showing in Xentry.
The blower motor regulator is as old as the car at 13 years old. I've never had this problem prior so now I'm wondering if it could be the blower motor as mentioned above being defective... I threw the old blower motor out so I can't test anything. Would hate to buy a new blower motor just to test but the indication in Xentry shows the regulator problem.... just think it's weird that having this problem shortly after replacing the blower motor.
-Nigel
2008 E350 Base -
Pretty much currently dealing with the same parameters on my parents car.
Last year their MB had a squeaking blower motor - especially when making R/L turns.
So I ordered the BEHR OEM Blower motor from FCP, and swapped out the old OEM blower motor, and placed the 13 year old OEM MB Resistor on the new FCP/BEHR blower motor.
All has been fine w/ the HVAC for over a year of heavy use, until this week...
It's starting to get hot outside, and yesterday my father called up, and said verbatim "the A/C wasn't getting cold until at least two minutes of driving."
So, hearing that, I assumed that after 14 years, the FREON was low.
I referred them to a local independent MB shop, and told them to get the Freon recharged.
Shop recharged Freon (it was low), took it for a test drive, and the Tech experienced the same conditions that the car came in with.
Shop did a deeper probe, and have come up with the 14 year old blower motor resistor is in the process of going bad.
RE: Availability of Blower Motor Resistor: OEM Quality (i.e. Behr for $140) is on backorder everywhere, BUT you can easily get the M-B part starting at $350
The independent shop says that the ChiCom aftermarket part is garbage (they've tried it a couple of times, and it lasts only a few months) so they're going to spend the rest of the week and try to source a NEW OEM Behr part or a USED MB Part from the wrecking yards in South Sacramento.
I'll update when the circle is closed.
2008 E350 Base -
I ended up getting the Behr blower motor regulator from Ebay from England. The dude had 5 or 6 brand new and it was actually cheaper than anything here but shipping was 20 bucks. I think total cost was $150 to get it over here which put it higher than FCP Euro but lower than Pelican Parts... Got it in about a week.
I installed it and I was still experiencing the same behavior and was super annoyed. I was doing other things with the the car and had to disconnect the battery because I broke the optical loop when I was moving wires around and then tested it again and everything works. I drove the car up to PA via memorial weekend and had the air on the entire time. It worked going up and coming back home 4 hrs each way. I keep testing it and it's fine now. Honestly not even sure what was happening. Just had the car inspected for state emissions/inspection and it passed fine.
Seems like these cars need to be driven and not sit for a long period of time even if they are in fact on a battery tender...lol
So it appears my issue is resolved. I'll hook it back up to STAR just to see if anything is out of the norm, but any time I turn on the blower it comes on and adjusts fine now with the new blower motor regulator.
I definitely didn't want to spend the $3-400 for an OEM MB behr labeled blower motor regulator only to find out it didn't work either. My guess was that perhaps the new blower motor was pulling more current or drawing more than the older one was and it was throwing the regulator off or it's just by chance that the blower motor regulator was in fact going bad...At the time I replaced the blower motor I could have ordered the regulator but choose not to since it was working prior to that, it was the slight squeak the blower motor was making that I wanted to address. But air turned on fine prior to that.
This is the ebay link I got the blower motor regulator from:
MAHLE BEHR Aircon blower regulator and resistor PREMIUM LINE [ABR29000P] US | eBay
He's got 4 left.
-Nigel
Using the Part Number that you provided, I found it (supposedly) In Stock at Rock Auto
$100.79 @ Rock Auto
Link: https://www.rockauto.com/en/moreinfo...t=6557&jsn=908
I will continue to update this thread.
