E-Class (W211) 2003-2009
Experience Misfire
Old Mar 14, 2022 | 08:32 AM
ILuke's Avatar
Mercedes Benz e240
Experience Misfire
Check spark plugs
after cyclindar 6 Misfire conduct on OBD
A new plug fixed it
E240
W211
Old Mar 16, 2022 | 12:31 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
defective spark plug...
You replaced ONE spark plug and now the remaining 5 old ones are firing well?
Try to service these parts all at the same time to keep track of mileage record.
Misfirings are bad for the exhaust cats, engine wear and promote bad ignition coils.
What scanner are you using... any other faults??
Old Mar 16, 2022 | 01:00 PM
ILuke's Avatar
Mercedes Benz e240
R
Yes
diagnostic reported cyclindar 6 Misfire noted that there are 2 plugs per coil pack.
After the one change I scanned and the fault was gone,
Other faults: ESP defective visit workshopNow and again that error would show...
I'm hoping the Misfire fix was also a connection to the esp fault.
Another thing I was add I prayed to Christ about this
Now that in good faith with the workflow process brings it up.
Scanner : Konnewei
Thank you for your advice
Old Mar 16, 2022 | 01:48 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Aren't these plugs supposed to be swapped out about every 60K miles per Mercedes?
They ought to be like potato chips: You can't do just one...
