Brake Defective - Stop Vehicle (not SBC)
This message appeared.
The brake pedal stiffened extremely hard and I had no brakes basically. Thankfully I was still just parked outside my apartment block. Turned the key back, took it out, restarted the car and it was all gone. No sign of anything. Fast forward the same day, but in the evening - I've driven the car around 50 km or so during the day (highway) and I cold start it after a few hours (same temperature outside, maybe even colder), start driving and around 4/5 minutes later, while pressing the brakes the same thing happens, only this time I was on a crossing and narrowly avoided collision. Same procedure - turn the key, take it out, restart - everything is fine and dandy. I drove it the whole day yesterday - no signs of trouble.
I forgot to mention that both cold starts I didn't wait at all before pressing the brakes (the second time I just took off right away), I am mentioning that because when it's cold I usually give the car 1/2 minutes idle and then put it in D and give the tranny oil 1/2 minutes to get going. Didn't do that when all this happened.
Also I don't think it's the SBC going out, because it was replaced by MB official dealer under extended warranty 70 000 km ago. But I don't really know? Could it be it?
Personally I think it might be a battery or something. I think I should check the voltage. Small battery is 4 years old, the big one I don't know. Also I got the "Electrical malfunction ; Conviniences switched off." message a couple of times since I have the car (usually when it's cold) but never paid much heed to it since I figured it's typical w211 behaviour. After I drove the car for a bit and started it back again after a while it always went away.
Any ideas?
It does sound like you might need batteries too; I'll bet there's a code in your computer for an error there.
Cars that stop reliably are arguably better than cars that go.
But how to stop then...???
Honest shortcut: don't drive this vehicle!
I 've been in a car with busted brake lines... it scared the living Jesus out of me.
But assuming he's still alive, it could still be the SBC pump. It's a rebuilt pump so it could fail sooner than expected. That's typical of how they fail, no brakes and then brakes when you restart it. There's a backup SBC battery and I think you usually get warning notices when the battery voltage is too low. It's a 25 year unlimited miles extended warranty so the SBC is still covered.
