E-Class (W211) 2003-2009
What is this?
Old Jul 24, 2022 | 04:41 PM
echo512's Avatar
2008 E320 Bluetec
What is this?
I was checking bushings and found this hanging around the bottom of the spring coil and perch of the strut. It is very light weight maybe more foam than rubber.
I've been trying to diagnose suspension noise, not finding anything obvious except this. Would whatever this is deteriorating be my issue? I can't find any part number for this.
Old Jul 24, 2022 | 05:24 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
suspensions
suspension are the sturdiest parts of the car. Light foam is not rated for strength. That piece looks like a cushion for the spring coil bottom.
Searching for noise, have you checked these:
#1 ball joints
#2 sway bar bushings
#3 stab. links
#4 control arms
Old Jul 25, 2022 | 08:38 AM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Perhaps this part
https://www.fcpeuro.com/products/mer...4aAqx1EALw_wcB
Notice the part fits the next generation W212, not listed for the W211
Old Jul 25, 2022 | 03:30 PM
ot1's Avatar
ot1
2006 E320 CDI
When you purchase a new coil spring, that isolator is glued onto the bottom of the spring, during the process of installing new springs recently, that part fell off. I already had Bilstein B6 series, replacement shocks and purchased a separate isolator, Which doesn’t fit that great but works, so I didn’t need that part you show.
I wish I could find a properly fitting bottom isolator for use with the Bilstein B6.
Old Jul 25, 2022 | 10:07 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Repeating Calibenzdriver:
#1 ball joints <— NUMBER 1 CAUSE OF SUSPENSION NOISE ON W212
#3 stab. links
#4 control arms
Old Jul 26, 2022 | 12:33 AM
echo512's Avatar
2008 E320 Bluetec
I checked the ball joints, and they all looked good. No cracks and visually looked good. Bushings all looked solid. I didn’t remove the under pan to see if the stabilizer had bad mounts.
My car just ate the serpentine belt so focusing on that first before returning to this.
Old Jul 26, 2022 | 01:08 AM
simplicity
in all honesty, the suspension noises are mostly nagging from sturdy parts that are purposely built
Replace your suspension wear items when you get a chance, all together or one after the other, just like your serpentine belt, tensioner and idlers.
Old Jul 26, 2022 | 01:45 AM
Odd Piggy's Avatar
As an FYI based on experience, W211 lower ball joints can look good, be in spec, and still be noisy. The design changed from the W210 lowers. How many miles on your E320? 90k-110k is usually where they begin to squeak.
Good luck with that serpentine belt. Unless the belt is really old, a shredded one is usually caused by a bad pulley. Mine was a failed idler bearing.
