E-Class (W211) 2003-2009
"Number plate light not working" - wrong, but it won't clear.
Old Jul 30, 2022 | 12:08 PM
Axe Murder's Avatar
E55
Hello. S211 ´08 E280 wagon here.
Can I clear error messages in the computer somehow? I fixed the number plate light, but it still claims error whenever I start the car.
I have a BlueTooth ODB2 plug, but Torque says there are no fault codes to clear.
To make a short and boring story long and boring instead:
I got the error message that my left number plate light was out. It was indeed burned out. I replaced it. Still would not come on. I rolled the bulb around. It would flicker, so: corroded contacts?
I disassembled the socket and cleaned it thoroughly. Both lamp sockets while I was at it, because if the left one is faltering the right may also any time now.
I put the stuff back, and both lamps work great. Except that whenever I turn on the ignition, I get a message: "LEFT PLATE LAMP DEAD, RIGHT PLATE LAMP DEAD".
I went into the service menu (ignition on, push Reset three times, voltage menu) and erased everything I could find. No difference. Still get an error message every time I turn it on, even though both lamps operate as they should.
Anyone have a clue as what I should do now? Get a better ODB2-thing?
Thank you in advance for any usable information!
Old Jul 30, 2022 | 02:29 PM
Heguli's Avatar
2006 E280
Get iCarsoft MB V2.0 or similar, Mercedes specific scanner. Those general scanners usually don't go deep enough to the system.
Old Jul 31, 2022 | 07:09 AM
Axe Murder's Avatar
E55
Thank you very much for this valuable advice!
That scanner market is a jungle, I appreciate guidance.
Old Jul 31, 2022 | 09:02 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
The error should clear itself after a few cold starts.
Old Aug 1, 2022 | 06:40 AM
Axe Murder's Avatar
E55
Aight, cool. Thanks!
Going to get that scanner anyway. I like tools.
Old Sep 14, 2022 | 08:27 PM
Axe Murder's Avatar
E55
The error did not clear itself, but a bit of poking with the iCarsoft device fixed it.
It also fixed an error where the front power windows would not "auto-close" - the last half year I have had to hold the button all the way up. Now it works as it should.
Old Sep 15, 2022 | 12:04 AM
2013 ML350 Bluetec
And another Icarsoft has paid for itself.
