Is It Possible to Minor Scratch In The Wood Finish?
Subscribe
Oct 8, 2004 | 01:54 PM
Last night when leaving work, a metal end cover of my brief case contacted one of the triangular wood pieces of the console. The scratch is not deep, but easily seen at certain angles.
It certainly isn't major, but it is the first real imperfection.
Does anyone know if this can be repaired, or at least slightly repaired so it is not so noticeable?
Thanks.
Reply 0
Oct 8, 2004 | 01:57 PM
I used a scratch repair wax designed for plastic on my wood trim in the CLK before. Must say that the results weren't that great but it was better than before. Bought it from AutoZone but I'm sure you can find it anywhere.
Reply 0
Oct 8, 2004 | 09:03 PM
This why I love the trunk popper on my keychain
Prevention. Briefcases and other hazards ride in the trunk. Each time, every time.
Reply 0
Oct 8, 2004 | 09:50 PM
Quote: Prevention. Briefcases and other hazards ride in the trunk. Each time, every time.
Good advice
Reply 0
Oct 9, 2004 | 12:27 AM
Which piece is it? It may be cheaper and easier to just buy the replacement.
Reply 0
Oct 9, 2004 | 01:41 AM
I was wondering that myself. It is the triangular buttons to open the center console. Knowing MB, I'm sure they are at least $80.
Reply 0
Oct 9, 2004 | 01:57 AM
Yeah.. It also has the aluminum strip on it.. Anyone know the part number on those two pieces?
Reply 0
Oct 9, 2004 | 08:42 AM
Quote: Last night when leaving work, a metal end cover of my brief case contacted one of the triangular wood pieces of the console. The scratch is not deep, but easily seen at certain angles.
This highlights my point with the new centre arm rest and different types of jewellery worn about the wrist area.
Have you considered any of the antique restoration products?
Personally I would probably replace the damaged part and kick myself
Regards,
John
Avery rough day in Torquay
(galloping 'white horses')
Reply 0
Explore
Oct 9, 2004 | 01:21 PM
Use some polishing compound or "scratch remover" with a soft cloth, rubbing it out will remove it...i have done it many times.......i even used a dremel rotary cordless buffer to take out scratches on the wood, just dont remove too much of the clear coating on the wood
Reply 0
Oct 9, 2004 | 03:08 PM
Quote: Use some polishing compound or "scratch remover" with a soft cloth, rubbing it out will remove it...i have done it many times.......i even used a dremel rotary cordless buffer to take out scratches on the wood, just dont remove too much of the clear coating on the wood
Thanks. Is that "scratch remover" specific for wood or varnished finishes? Definitely worth a try, and if it doesn't work or I screw it up even more, than I will replace it.
Reply 0
Oct 9, 2004 | 09:22 PM
hey Calbenzo, I also scratched the wood on my E430 before. It was a pretty bad scratch caused by a muffler that I put on the rear seat of the car. But I took out the scratch by first using a 3M medium rubbing compund followed by fine rubbing compound. And I finished it with the swirl remover from Meguiar. It was perfect and you can not even tell. It is easy to remove scratches on the wood trims because they put a thick coat of clear coat and the clear coat is pretty soft.
Reply 0
Oct 10, 2004 | 02:54 AM
Thanks Amgkoo,
Is that compound something found at a hardware store, or an autoparts store?
Reply 0
Oct 10, 2004 | 05:08 PM
I bought all that from Autozone. They come in pretty handy when you want to get rid of minor scratches.
Reply 0
Oct 11, 2004 | 02:16 PM
Quote: Thanks. Is that "scratch remover" specific for wood or varnished finishes? Definitely worth a try, and if it doesn't work or I screw it up even more, than I will replace it.
Look for something that repairs plastic, not wood. The top layer that was scratched off is actually a plastic-type coating.
Reply 0
Oct 11, 2004 | 02:23 PM
you wont screw it up, us an old t shirt and use your index finger to rub the scratch out, use a tiny amount of the polish (i used a scratch remover in a yellow bottle, forgot the brand) and rub gently at first and gradually increase pressure as the scratch dissapears.
Reply 0
Oct 11, 2004 | 09:34 PM
I have scratched those wood center console pieces myself, and I read on one of the boards to use Zaino car polish to remove them. I tried it, and it buffed it right out -- the pieces look brand new!!! Use on light scratches with your fingers or a cotton rag to lightly buff - it will work on deep scratches to soften them but not remove them.
Good luck and let me know how it goes!
Reply 0
Oct 12, 2004 | 10:33 AM
Thanks for all the suggestions. I'm sure one of them will work.
Reply 0
Oct 14, 2004 | 08:23 AM
I've used a normal paintwork scratch remover on those triangular pieces with great success. Think it was P21S, but any should work.
Reply 0
Subscribe
Currently Active Users (1)
