03 E320. Spent 3800 in suspension work and m, now weird ABS or buzz vibration sound?
Now I have this issue that's wasn't there before. When I turn the wheel wide, mostly in reverse it sounds as if something electronic is turning on for about 3 seconds then off. It also makes a weird hollowing sound in reverse. Mechanic said suspension is fine as he doubled checked.
At first I thought compressor pump, but I dont have air suspension. Then I thought maybe ABS or wheel sensor or something? No ABS or ESP light on, so wtf? My mechanic is kinda stumped too. It also feels like I'm pulling a parachute now too. The car slightly vibrates on the road and doesnt glide like it used too. It doesn't seem like a tire balancing issue either. It doesn't pull on braking so doesn't seem like a stuck caliper. Maybe this is in my head cuz everything is now tight and new? The suspension is very nice and no rattles or thumps like with the old suspension. Also the ABS doesn't engage under normal braking so seems the ABS is ok, so I really don't know what is going on.
Any help would be appreciated
Honestly it feels like im driving with the parking brake on too. Do you know what wheel the parking brake is on?
No brake, ABS light on. Nothing. He better not tell me it's some ABS issue. Steering seems real heavy too but that may be the new tires. Car doesn't pull at all either so caliper doesn't seem frozen
Thanks !
Thanks !
BTW, Did you check the fluid level in your power steering?
try to post a clip of the sound you’re hearing.
My mechanic literally checked everything.
This SBC thing thing you mentioned just pressurizes the brakes. It doesn't pulsate or engage anything? It still sounds like runs a few seconds whenever I first start the car. I Cant even drive it on the expressway because it doesn't feel stable. 😫
I'm going to somewhere else for another alignment first. I really feels it's out of alignment too.
The issue with my SBC could be completely unrelated to anything and just be coincidental. Buzzs every time I brake slowly. Fells as if I'm riding with brake on and pulling a parachute. I heard there is also some transmission reflash they have to do on 03 and 04s with the torque converter. What a nightmare. Hopefully this falls under that extended recall for the SBC! THANKS!
