E-Class (W211) 2003-2009
2009 e550 4Matic front end problems
Old Feb 3, 2023 | 11:11 PM
Johnnyb46's Avatar
2007 cls 550
When I drive bout 30mph or try to pedal to the metal the gas the front of my car wheels wobble like something’s lose I changed the passenger side axle upper control arm inner tie rod and outter tie rod I don’t knw wat it can be I knw I need alignment car pulls to the left can a bad air shock make the wheels wobble if it’s worn
Old Feb 4, 2023 | 04:05 PM
konigstiger's Avatar
'71 Pinto
How about axle...
Old Feb 4, 2023 | 04:15 PM
Johnnyb46's Avatar
2007 cls 550
How about axle...
I changed the passenger axle it was bad the driver side not bad
Old Feb 4, 2023 | 04:44 PM
'71 Pinto
Well move on to steering knuckle/lower control arm, torsion bar links and dare I say wheels.
Old Feb 4, 2023 | 04:46 PM
Johnnyb46's Avatar
2007 cls 550
ball joints are good control arms are good knuckle good can a bad tire cause wobble symptoms
Old Feb 4, 2023 | 04:55 PM
'71 Pinto
Yes, wheel/tire, best way to rule out is have them road force balanced: locate a balancer https://www.hunter.com/wheel-balance...d-force-elite/
Old Feb 4, 2023 | 04:57 PM
Johnnyb46's Avatar
2007 cls 550
ok thnks I took my car to get both front wheels balanced tho and thy said thy where perfect thy charge me $30 for both but my tires cud be bad and again when I push down on my car the front are bouncy the shocks might be bad right no air leaks but bouncy
Old Feb 4, 2023 | 07:27 PM
'71 Pinto
You don't have shocks equipped with Airmatic struts stretch to think these are causing tire 'wobbling'.
Old Feb 4, 2023 | 07:35 PM
Johnnyb46's Avatar
2007 cls 550
I have a 4Matic with air ride shocks
Old Feb 4, 2023 | 07:36 PM
Johnnyb46's Avatar
2007 cls 550
Old Feb 5, 2023 | 08:41 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Check your lugs...I recently had my tire balanced/ rotation and they had the lug off just a but which was making a funny noise on passanger side front. I didnt even make it out of parking lot when i flag tech down and had them check and redo all the corners. All was gud since. Just my humble opinion
R,
2Merks
Old Feb 5, 2023 | 08:42 PM
Johnnyb46's Avatar
2007 cls 550
How about axle...
yes I changed the axle to passenger side driver side good
Old Feb 5, 2023 | 08:43 PM
Johnnyb46's Avatar
2007 cls 550
R,
2Merks
yes I did that to they where fine but whoever had this car didn’t put wheel spacers on it the rim haves plenty of play on the rotor until u tighten down the lugs
Old Feb 5, 2023 | 08:48 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Oh wow...do you think the spaces are needed?
Old Feb 5, 2023 | 08:50 PM
Johnnyb46's Avatar
2007 cls 550
yes they are needed for sure unless I change my wheels back to factory the back are 285/30/20 front are 255/35/20 but I dnt think it’s thst might be my air ride shocks
Old Feb 5, 2023 | 08:57 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
... At best i would seek another shop 2nd opinion. Hope that helps.
R,
2Merks
Old Feb 5, 2023 | 08:58 PM
Johnnyb46's Avatar
2007 cls 550
R,
2Merks
thnks will do
