E-Class (W211) 2003-2009
Rear headrest problem
Old Mar 18, 2023 | 10:45 AM
MB_user's Avatar
MB220cdi W211
Post Rear headrest problem
W211 Folding Backrest.
I have continuous currunt to rear left and middle headrest even switch is not depressed. Right rear is working fine. I have disconnected the cable (beside backrest) for the left and center headrest motors. Any suggestions or maybe i need wiring diagram...... or where is the headrest controller?
Any help would be appreciated
Old Mar 20, 2023 | 11:58 AM
e350forme's Avatar
fleet
doesn't it not fold unless you move the bottom cushions up against the front seats?
this should do the trick. you are folding the rear backrest down onto the seat cushions. they fold back if you move them wiggle them
Old Mar 23, 2023 | 05:02 AM
MB_user's Avatar
MB220cdi W211
The picture is for illustration of my seats
Headrest motor get power all the time and burns out. I have changed the headrest motors once, but I won't connect the motor wiring until the problem is fixed.
Old Mar 28, 2023 | 12:27 PM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 28, 2023 | 02:36 PM
MB_user's Avatar
MB220cdi W211
konigstiger.... Thank you for picture and pdf files.
I have disconnected plug from seperation point, because headrest motor have continuous 12v power.
Still i cant understand how to check why its always powered. Are headrest connected to a module?
Old Mar 28, 2023 | 03:32 PM
'71 Pinto
Check corresponding rear SAM connectors/pins per wiring diagram could be internal SAM malfunction.
