07 E350 PZEV Woes (new tank didn’t fix issue)
My car is a PZEV and was having issues starting the car. Before replacing the tank, it would crank and eventually start after a few cycles.
- replaced crankshaft sensor - no change
- got fuel tank replaced - I’m over on date on the 15 year/150k extension. MBUSA wouldn’t help and no managers will call me back.
- car is starting better most of the time. However if I turn it off and remove the key, go to start it 20 min later it will start-ish and then die within 5 seconds.
- replaced fuel pump relay
- getting over 12v on the sending unit wiring, just waiting for it to happen again to see about voltage when it dies.
Am I missing anything else?
if you take the air box off, and spray the throttle body with some starting fluid, will it start? If it does, it is a fuel delivery issue; otherwise, it is am ignition issue.
But, the first advice is always scan for codes with MB specific scanner, check fuel levels with scanner not the cluster
