E-Class (W211) 2003-2009
2009 E550 4Matic P2784
Old Mar 30, 2023 | 06:00 PM
Johnnyb46's Avatar
2007 cls 550
What can this code mean do I need new transmission solenoids I just did a conductor plate and new connector replacement
Old Mar 31, 2023 | 11:39 AM
konigstiger's Avatar
'71 Pinto
OBD p2784 = speed sensors. Sensors are incorporated into conductor plate odd replacement is causing this code. Possible defective CP, current part # is 1402701161 (need VIN to confirm).
Old Mar 31, 2023 | 11:46 AM
Johnnyb46's Avatar
2007 cls 550
WDBUF90X69B438846
Old Mar 31, 2023 | 11:58 AM
Johnnyb46's Avatar
2007 cls 550
I wud need these right
Old Mar 31, 2023 | 12:23 PM
'71 Pinto
If steadfast on replacing solenoids rather than revisiting conductor plate itself where problem resides.
File Type: pdf
File Type: pdf
Old Mar 31, 2023 | 12:52 PM
Johnnyb46's Avatar
2007 cls 550
so I shud look at the conductor plate instead of replacing the solenoids is wat u saying
Old Mar 31, 2023 | 01:19 PM
'71 Pinto
Have you read post 2?
Old Mar 31, 2023 | 01:22 PM
Johnnyb46's Avatar
2007 cls 550
yes speed sensors might be a defective conductor plate
Old Mar 31, 2023 | 01:24 PM
'71 Pinto
And...
Old Mar 31, 2023 | 01:52 PM
Johnnyb46's Avatar
2007 cls 550
[QUOTE=konigstiger;8750769]And...[/QUOTE
help me out and what lol 😂
Old Mar 31, 2023 | 02:09 PM
'71 Pinto
OBD code 2784 = speed sensors. Speed sensors are built into conductor plate (CP) and not replaceable separately. You said you replaced conductor plate, unless I misunderstood, so two choices. CP needs to be replaced again possibly being defective or pull codes using Xentry (MB diagnostics).
Old Mar 31, 2023 | 02:53 PM
Johnnyb46's Avatar
2007 cls 550
Ok I understand now and yes it have been replaced I got it off eBay but this time ima get one from the dealership instead
Old Mar 31, 2023 | 11:26 PM
cetialpha5's Avatar
You bought a used conductor plate on eBay? Or was it new? Lots of fake parts out there too.
Old Apr 1, 2023 | 12:13 AM
Johnnyb46's Avatar
2007 cls 550
no new this the part
