E-Class (W211) 2003-2009
2008 e350 radio issue
Old Apr 20, 2023 | 11:20 AM
tauger's Avatar
2008 e350
I've owned my 2008 e350 for many years and recently it started doing several odd things. The radio/cd/COMMAND has always worked fine but all of a sudden:
1. The radio stays on after turning the engine off and removing the key
2. COMMAND/radio/cd shuts off randomly when driving down the road
3. I get a message on COMMAND saying "Please start the engine. Otherwise, COMMAND will switch off in 10 seconds" Obviously the engine is running when I get this message. It never does shut off and I can make the message go away
I initially thought the auxiliary battery was acting up but the car doesn't have one. I checked under the cabin air filter in front of the passenger in the engine bay, the driver side access hatch on the left side of the dash (drivers door must be open) and in the trunk. The main starting battery is in the trunk on the passenger side.
I tested the battery and alternator and both are fine. The fuse to the radio is good although it's a 5 amp and the diagram shows it should be a 15. Doing online research I saw that another e350 had a 5 also so not sure what's up with that. Regardless everything about the COMMAND system/radio/cd works fine other than the problems mentioned above.
Anyone have any ideas? Thanks.
Old Apr 20, 2023 | 11:37 AM
konigstiger's Avatar
'71 Pinto
Need to have someone check for fault codes using Xentry (MB diagnostics) head unit may need replacement. Provide VIN I’ll pull compatible part #s to shop in the event unit is confirmed bad or you want to circumvent definitive diagnose and replace.
Old Apr 20, 2023 | 02:14 PM
tauger's Avatar
2008 e350
Thanks for the reply. I would definitely be interested in the part #s in case it comes to that. VIN is WDBUF87X98B262812. I do have an OBD reader and it shows no error codes.
Old Apr 20, 2023 | 02:52 PM
'71 Pinto
Shop the following part #s used.
File Type: pdf
File Type: pdf
Old Apr 20, 2023 | 03:04 PM
tauger's Avatar
2008 e350
Thanks for the info. Fingers crossed it doesn't come to this as I'd probably just live with it
Old Apr 30, 2023 | 07:28 AM
tauger's Avatar
2008 e350
Believe it or not the whole issue was caused by a bad battery. First thing I did was to have it checked and they said it was fine but came out to use the car one day and it was completely dead. I replaced the battery and all the issues I was having went away
Old Apr 30, 2023 | 03:54 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Plan B
Do you have handheld scanner to read codes? Now would be a good time to buy an iCarsoft or similar.
Disconnecting the battery does help temporarily sanitize crazy modules. It's quick easy reboot.
Also you can connect a CTEK float charger to prevent drain inconveniences.
MB temperamental modules can get restless with very little warning or protection .... Get a jump battery booster pack to ensure unconditional startings.
Old Apr 30, 2023 | 06:23 PM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Totally believable. Any drop in voltage plays havoc with electronic modules. They have a threshold level of power they need to operate or they switch off, rather than run at a lower level of efficiency. Thats why good mechanics test your electrical system first.
