08 E350 Wagon - Button to Close the Tailgate, Change Bulb
Simple fix is to take 10mn to resolder a few loose internals - How look around links in my signature. You can try, nothing to loose with a module already bad.
No1 Tip : unplug batts before modules will minimize pain when car spots misssing gear and gets lunatic. Read that simple tip again.
No power helps the car know nothing - Disconnecting batt Reboots the system into a very responsive mood 👏
If that does not fly then deal with the amazing trunk pull module and schematic diagram of this system.
I know the 212 trunk module, unsure about 211 incarnation... may be a close match.
It's a simple entry-level mix of electromechanicals to pull on trunk springs... needs lube now!!
This is fairly entry level stuff.... no sweat necessary.
