E-Class (W211) 2003-2009
Automatic open, close tailgate function.
Old May 18, 2023 | 05:52 AM
Timo Schroeder's Avatar
Class S 500 M278
What else is there to do - I have changed both dampers up under the ceiling, refilled with new hydraulic oil in the servo motor.
The tailgate opens and closes without problems when I help it at first movement by activating the handle.
On the left side, the tailgate opens approx. 1 cm., but not on the right side.
When I help, by using the handle, everything works fine.
I can hear "something" that is "working" but.......
Old May 18, 2023 | 08:24 AM
tjts1's Avatar
C320
Your tailgate pump is low on oil.
Old May 18, 2023 | 08:30 AM
Class S 500 M278
No, unfortunately not - I've just filled, flushed with new oil - it doesn't change anything 😕
Old May 18, 2023 | 09:06 AM
Heguli's Avatar
2006 E280
I have the same issue, and I believe the latching mechanism is sticking.
Old May 18, 2023 | 09:15 AM
Class S 500 M278
Ok - I can see that a lot of people have the same issue. I've been trying to find a technical drawing, sketch or similar of the whole system, but so far without any major success. I'm pretty sure, it's just something simple small issue, but there to start....
Old May 18, 2023 | 03:46 PM
Class S 500 M278
Could there be something like a "sensor strip" as on the w164 ML class?
Old May 18, 2023 | 03:48 PM
tjts1's Avatar
C320
Then its time to replace the pump.
Old May 18, 2023 | 03:52 PM
Class S 500 M278
Pump working ok, it's not the prothem.
