Engine Check light
You can not work on W211 without using a scanner to gain insight... the big deal is not CEL, it's the ECU that sensed something's wrong.
You could reset or ignore the dash light but the engine won't work right until repaired.
My e200k went into limp mode yesterday and i was able to read and reset the 3 codes it was showing with this reader/scanner i already had
hopefully it will drive far enough to get me to a mechanic if i need one
