E-Class (W211) 2003-2009
320 CDI wagon - aircondition issue.
Old Jun 8, 2023 | 11:11 AM
Timo Schroeder's Avatar
Class S 500 M278
I just need a little help, gent's.
The aircondition is completely crazy - left side no cooling, only outside air.
Right side, nice chilled air.
The center console down between the front seats and to back seat very hot air.
Where should I start troubleshooting?
Old Jun 9, 2023 | 03:04 PM
Class S 500 M278
Solved - just needed top up of refrigent.
Old Jun 9, 2023 | 03:50 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
poor AC cooling
Where you should start is by scanning the HVAC AAC Module for a fresh list of faults.
Then you review every Temp sensors and pressure data using scanner.
"Low refrigerant".… that means leak!
In AC system leaks are not easy and nor cheap to repair well the first time.
Do you know how to use a UV die or gas detector to help locate discharge location ???
Old Jun 10, 2023 | 10:58 AM
Class S 500 M278
The AC workshop said it's quite normal that aircondition systems losses a bit of refrigent, in general it's good to go for a check and top up every second year, they told - I've got a top up of refrigent, and now everything goes well, and no leaks found.
Old Jun 10, 2023 | 03:24 PM
Pls come again!
Right now the aircon shops are swamped... go in January and they'll start replacing expensive components.
Your AC shop can't locate your leak... then find it yourself!
Simply look for oily stains near your AC circuit loop.
Old Jun 10, 2023 | 03:32 PM
W211-(E500)'s Avatar
2005 Mercedes E500
Yes this is very true. I had a BMW that was 11 years old and the AC wasn't very cold. After adding Freon it ran ice cold for years - no leaks ever were found.
Old Jun 29, 2023 | 12:08 AM
ot1's Avatar
ot1
2006 E320 CDI
Arrow
lots of vehicles have slow leaks at the compressor shaft seal, UV dye is the only way to find very slow leaks.
how much did the shop charge to top off your system?
