Do '03 E500 w/ Xenon have adaptive headlights?
Do the Xenons on the 2003 E500 turn right/left like they do on the 05s adaptive xenons?
Thanks!
Does anyone with an 05 w/ adaptive headlights have any comments on how their's work?
Thanks!
-s-
Now, I will say that in "city" driving conditions I will agree that for the most part the feature is quite hard to notice and seems hardly worth it.... If I owned a car that I had to retrofit the feature into, then I would say its not worth the extra $$$$ as the lights themselves are great (as previuosly posted). But for us owners that have it with the optional Bi-xenon lights, then I would say its well worth it as the "active" feature was free...... Anyone who can't see a difference is either not driving on dark enough roads or can't see....
I guess in your rural driving you don't need to make medium speed sweeping up-hill turns to the left and have the road above the cut-off, with oncoming traffic. This situation makes the contrast extremely high between the bright lighted area and the completely unlighted road (tree covered road or new moon night). This is one reason very bright headlights with a sharp cutoff are not the solution for all driving.
Maybe you don't drive fast enough to have the headlight tracking lag behind your steering input?
Why do you assume that everything is exactly the same for you as for everyone else? You can just relay your experiences, rather than commenting on others' opinions.
-s-
-s-
Regards
I just bought band new 03 Bi-Xenons from performance products and put them in my 2004. They work really well, but the head mechanic at my dealership said the the self leveling system could not be activated because neither the harness nor the wires were present in my car at the rear suspension.
I angled my headlights a bit lower than normal so I would not blind and get blinked at when I have a full trunk and 4 people in the car, they are still amazing, but I would like them to adjust themselves.
How did you get the self leveling to work? Were the wires already there in your car? I am not concerned about curve following because I already knew that the splash pattern was so good that it did not make that much of a difference.
Thanks,
Steve
No "belittling" intended.... I had no idea you were so sensitive, so I'll try to be on my best behavior around you... sorry.
-s-
Thanks,
Steve
You may be able to retrofit the harness if you already have airmatic!
-s-
