E-Class (W211) 2003-2009
Sbc break counter reset
Old Aug 18, 2023 | 10:05 PM
Nosbig's Avatar
2008 CLS 550
Hi there can someone please explain how to reset the break counter on the sbc on my 2005 w211 e500 with icarsoft MB V3.0 I have had the sbc unit reconditioned with new brushes and new accumulator and has been installed thank you in advance
Old Aug 19, 2023 | 04:10 AM
Heguli's Avatar
2006 E280
Can't be done with the iCarsoft. You'll need a specific SBC reset tool for that.
Old Aug 20, 2023 | 03:12 PM
shertex's Avatar
1991 300D, 2006 E320 CDI, 2014 E250 Bluetec
Here's the procedure using Star:
How to determine SBC total actuation count or to reset
Start engine. (Note: If you only are checking the total actuation count and not resetting the count, the engine does not need to be running.)
Start xentry, go through multiple menus to your car's data then select:
Control units
Chassis
SBC sensotronic brake control
Development data (should be at the bottom of the page)
Actuations
Complete index of Actuations
Break: To only get the count, select “Bremsenzaehler (DF_GetBrLiveTime)”. This gives the total actuations to date. To reset the count, go to the next step. If only monitoring for maintenance purposes, back out of the program now using F1 key.
Bremsenzahler aktualisieren und Lebensdauerzahler F neu berechenen
set ulNBR to 0, click F3
Bremsenzahler auf beliebigen Wert setzen
Lebensdauerzahler F neu berechenen und schreiben
log out of xentry
Do not turn off car.
drive for at least 10 minutes. (or let idle)
Old Aug 23, 2023 | 08:53 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Also, don't mess around with this system. I got mine replaced under extended warranty earlier this year. It needs to be diagnosed by official MB dealer, they will run checks according to a sort of checklist to see if you are eligible.
Please note, I got brake warnings last year and after ignoring them, my brake pressure was gone when I was driving about 60mph on the highway. That was terrifying...Again, get it sorted the right way
Old Aug 23, 2023 | 09:19 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
It makes me feel good inside when someone posts information that I put on the forum years ago. I've done the same gathering information posted by forum members before me. That's why we're here; to assist each other.
Old Aug 23, 2023 | 10:26 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
+1 on just taking advantage of the warranty. There's more to the system than a set of brushes and an accumulator. You do NOT want to be going 60mph in traffic when your dash turns red and you've only got 10% of your brakes.
Edited to add: Not to mention that I don't want to be in traffic with you in those conditions.
Old Sep 4, 2023 | 03:59 AM
rnd_ash's Avatar
2003 E55 AMG
I posted this on the AMG 211 forums....but it goes without saying. DO NOT RESET THE COUNTER! You are potentially putting yourself in serious danger.
SBC is an electric hydraulic braking system. It has a pressure generator motor (which wears out), and also a pressure accumulator (it too, also wears out).
The counter on the SBC module is increased based on how many brake applications are made and the force of each one, in order to gauge the estimated wear of the motor and accumulator. Of course, SBC also does a check on the pressure rails whenever the car is woken up before a drive, but the counter is a better way for it to gauge long term wear and tear.
Mercedes were quite conservative with the counter, so when you get the brake failure warning, it will always happen before your SBC actually fails.
By resetting the counter you are erasing the SBCs memory of its previous use, therefore trucking it into thinking all components on it are brand new....which for obvious reasons is seriously dangerous and stupid to do!
Loosing your brakes on the motorway is never worth it to avoid a trip to the dealer or a £300 refurbished unit....
Old Sep 17, 2023 | 10:55 AM
AlmostHappy's Avatar
W211sedan E500 4matic
Was the warning a ‘BRAKE visit workshop’? in addition to an esp and srs malfunction?
Would it be intermittent?
Old Sep 17, 2023 | 08:11 PM
I made pictures, they are in my build thread here: https://mbworld.org/forums/c219/8443...ml#post8651162
