Hi All,
New to this forum and I have a question. Hope to get answers to my 2000 E320 problem.
Had some issues with the car not passing smog check, but after replacing a vacuum hose that run through close to the EGR valve, the car passed smog. After about 2 months of driving, it sporadically, (I have a couple more old cars that I use), the CAR STARTED SURGING AT IDLE WHEN THE BRAKES ARE PRESSED AND THE SHIFTER IS IN "DRIVE". It runs good in low and regular speeds, in the roads and freeway otherwise. I looked at the intake all the way to the flapper valve, but the flapper valve opens and closes manually fine with no power. Any insight from the group would be appreciated.
Thanks,
Ray
Thanks,
Ray
BlackML550
close
- Join DateJun 2014
- LocationMelbourne, Australia
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2010 ML550 VIN WDC1641722A564750, 2010 B180
Liked:442 Times in 353 Posts
Did you find the source of the surging problem? I have something similar. Thanks
nd-photo.nl
close
- Join DateMay 2022
- LocationThe Netherlands
- Vehicle(s) I drive2005 CLS55 AMG W219 C219
Liked:499 Times in 429 Posts
If there are check valves, make sure they are working properly
