E-Class (W211) 2003-2009
Headlight low beams are flickering on and off
Old Dec 20, 2023 | 11:17 PM
Mr Bike's Avatar
'03 S55 AMG / '09 E550 4-Matic / '08 E350 4-Matic
I’m working on a 2008 E350. Both low beams won’t stay on. They are flickering on and off.
The high beams stay on, no problem.
They are factory halogen headlights.
Anyone know what the problem may be?
Thanks in advance.
Old Dec 21, 2023 | 12:18 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Xmas blinking HL
Thanks in advance.
Well there's a chance you're dealing with poor wiring associated with these HL.
What's is odd is they are usually on separate circuits to readily disfunction individually.
  • individual GND
  • individual Power
  • nothing common
you'll need to pull a schematic?
++++ WAIT.... ALTERNATOR: short brushes!!!
Check live voltage under load near 14v or below 12V ??
You can use a scanner to read that data.
Old Dec 22, 2023 | 02:08 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Are the bulbs ok? Best guess is probably wiring. Also check the wires inside the headlight housing. These can become brittle over time due to heat/cold cycles over the past +10 years
