E-Class (W211) 2003-2009
EPS warning light
Old Apr 9, 2024 | 11:11 AM
Zackattack0827's Avatar
2005 E55 AMG
EPS warning light
Hi, I have a 2005 E55 and I'm getting a EPS malfunction message and a DTC P0638 throttle actuator control range/performance - bank 1. When this happens I have no throttle response, vehicle will only idle. I was wondering If anybody was familiar w/ this concern and know what typically is the issue. I got a new throttle body jumper harness to the throttle body because the connector tabs were broken so I thought I had a bad connection. I'm thinking I might have a failed throttle body but, would like to see what other people say before I buy a new one. Thank you.
Old Apr 9, 2024 | 12:53 PM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Did you install a bigger TB (82mm by any chance)?
Old Apr 9, 2024 | 01:27 PM
2005 E55 AMG
Yes, it does have an 82mm Bosch throttle body. I purchased the vehicle back in Sept-Oct and I haven't really driven it since. Shortly after I got the vehicle home was when the throttle started acting up. Everything up till now has been done by the previous owner ex: Weistec supercharger, 82 mm TB, and tune. The only thing I've done since purchase has been installing a new battery. It has been in storage till now but, like I mentioned by the time I got it home it intermittently has throttle cut out will not do anything but, idle which even that is a little rough.
Old Apr 9, 2024 | 04:17 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Can you find and install an original throttle body? Have you tested the current throttle body using STAR/Xentry by testing the actuation via the Motor Electronics module? Can you go back to the factory tune just to see if the issue resolves?
Old Apr 9, 2024 | 05:13 PM
2005 E55 AMG
What is STAR/Xentry? I haven't done any test's on it as of yet, I just got the vehicle out of storage yesterday. I can't really go back to a stock tune w/ all the performance modifications on it but, I do not believe that to be the issue.
Old Apr 10, 2024 | 05:08 AM
The 82mm has been known to give some intermittent issues that are very hard to diagnose. For instance see this thread: https://mbworld.org/forums/w211-amg/...an-hiccup.html
STAR/Xentry is the specific MB diagnose/coding solution
Old May 6, 2024 | 01:28 PM
2005 E55 AMG
I read the tread and it's not what I'm going through.. though it might be a tune related issue, I'm not sure. I have absolutely "no" throttle response, the veh. only idles. I just installed 2 other new throttle bodies and it work for a little bit and then went right back to acting again. The veh. has a RaceIQ tune on it. I'm pulling my hair out trying to figure this out.
Old May 7, 2024 | 10:55 AM
2005 E55 AMG
I not whining, I'm looking for solutions. Only positive feed back would be appreciated. Thank you.
