E-Class (W211) 2003-2009
Check Oil without dipstick
Old Nov 20, 2004 | 07:01 AM
Fastbuck's Avatar
2019 Mercedes Benz S500L AMG Premium Plus
Sorry if this detail has been posted previously, but I could not find it.
After playing around with my W203 I found out how to get a more accurate oil level on my W211 too. This is on a Jan 2004 E320 CDI.
1. Insert key to position 1. (Must be taken out and reinserted if you have been driving).
2. Select standard display in MFD ie Temp/digi speed
3. Press the reset button at left side of cluster 3 times in quick succesion.
4. You will now see current battery voltage ie UB 13.9
5. Press up arrow on steering wheel. This takes you to some stats inc SW version. Note engine oil level at bottom. You will need to start engine for this to register. Contrary to the normal way to check oil, you will get a more accurate reading by this method with a COLD engine.
6. If you press the up arrow again you get the VIN number
7. Press it again you get some dyno setting (WTF that?)
8. Press it again it takes you into a service menu. WATCH WHAT YOU ARE DOING IN HERE AS YOU MAY CANCEL A REQUIRED SERVICE ITEM IN ERROR.
YOU CAN DRIVE THE CAR IN THIS MODE AND WATCH THE SUMP OIL LEVEL FLUCTUATE. HOWEVER, BE WARY AS I UNDERSTAND THAT IN THIS MODE THINGS LIKE BAS, ESP ETC ARE DISABLED!!!!
To get back to normal just take the key out again.
Have fun!!!!!!!!!!!!!!!!!!!
Old Nov 20, 2004 | 09:27 AM
BudC's Avatar
2011 E550, 2013 GLK
I found this out too but you pointed out one thing I didn't know, that you had to start the engine to get the oil level.
Thanks for the Info.
Old Nov 20, 2004 | 09:41 AM
ATS's Avatar
ATS
2004 E500 / 2001 C240
This has been posted before.. I was in there and tried to find a way in there for 6 months. Finally someone here posted how to do it..
With the DYNO you can also completly disable traction control.
Old Nov 20, 2004 | 09:42 AM
ATS's Avatar
ATS
You do not need to start the engine, just turn to position 2.
Old Nov 20, 2004 | 10:25 AM
BudC's Avatar
2011 E550, 2013 GLK
Thanks, that makes more sense.
Old Nov 20, 2004 | 12:21 PM
Barry45RPM's Avatar
2015 ML 350
Dyno Setting
I remember reading somewhere that when you are IN the dyno setting, the ABS, and "traction control" stability systems, and a couple of other things that allow the car's computer to intervene and influence handling are turned off. It is designed so that when on a dyno, the car can not influence power measurement in any way.
Old Nov 20, 2004 | 12:55 PM
HELL ONA HARLEY's Avatar
Build date 2-04 E500
Originally Posted by Barry45RPM
I remember reading somewhere that when you are IN the dyno setting, the ABS, and "traction control" and a couple of other things that allow the car's computer to intervene and influence handling are turned off. It is designed so that when on a dyno, the car can not influence power measurement in any way.
Heres the details......... https://mbworld.org/forums/showthrea...&highlight=ESP
Old Feb 11, 2005 | 10:55 PM
RJC's Avatar
RJC
Various
I just checked my oil using the standard method and the display said "reduce engine oil!" but then I used the method above and it registered 8.0 quarts, the car was at normal op temp when I turned it off and I let it sit for about 10mins before checking. 8.0 is exactly how much oil the 500 is supposed to have, is the above test only to be used when cold? Should I bring the car to the dealer and have them reduce the oil or is the first display inaccurate at times? Thanks
Old Feb 12, 2005 | 11:04 AM
cdiken's Avatar
2005 Carlsson CD32 E320 CDI Inline-6
8.0 on the high-side...
You should take it to the dealer, could be overfilled, or....sensor out of range.
if you're overfilled its not by much, full fill is 7.0-7.5 qts.(I THINK NOT 100% positive). Verify this independantly.
The real issues is...since there is no dipstick, that sensor needs to work properly. It could be off, spitting out false high readings, thus IF your engine ever becomes critically low, LOW OIL PRESSURE could be your only warning before your engine implodes.
KB
Old Feb 12, 2005 | 11:49 AM
BudC's Avatar
2011 E550, 2013 GLK
Are you sure it didn't say 8.0l? I'm in the US and mine displays the level in liters. The capacity of the V8 is 7.5 liters and the capacity of the V6 is 8.0 liters. If the V8 showed 8.0 liters that's too much. Did you recently have the oil changed or add oil?
Old Feb 12, 2005 | 12:52 PM
RJC's Avatar
RJC
Various
Smile
Update.
I checked this morning in both modes advanced and normal, normal displayed oil level ok and advanced showed 7.8 quarts, according to my owners manual 8.0 quarts is the capacity for the V8 500.
Old Feb 12, 2005 | 01:05 PM
BudC's Avatar
2011 E550, 2013 GLK
Update.
Did your car indicate 7.8Q (for quarts) or just 7.8? The reason I ask is that mine shows the value in liters such as 7.8l and I have a US car.
Old Feb 12, 2005 | 01:13 PM
RJC's Avatar
RJC
Various
Quarts
Old Feb 12, 2005 | 01:31 PM
BudC's Avatar
2011 E550, 2013 GLK
Quarts
So it says 7.8Q? I wonder why mine shows 7.5l. Now I'm really confused.
