Coolant recovery line/reservoir replacement
Hey all, i just recently bought my first Mercedes, a 2008 E350, and am trying to learn to diy more. I just replaced my serpentine belt but in the process leaned on this return line and partially broke the connector on the reservoir. From what i gathered on another thread, if the reservoir is brittle i should probably just replace the whole thing right? The hose still sits in there but doesnt have a good seal so i didnt know if i could use something to re-secure it or just need to get a new reservoir. Also wasnt sure if i should avoid driving it or can maybe put some electrical tape on there to help hold it in place and it would be fine for the moment. I dont know too much about the cooling system or how it’s pressurized so appreciate any input. Thanks!
https://mbworld.org/forums/e-class-w...over-tank.html
Be advised the bleed line part number is for the M113 V8 engine; yours may be different so use the link to the parts catalog and look up your car.
thanks! Pulling out the coolant it seems like theres dirt in the reservoir. Not sure how big of a concern that is for the rest of the coolant in the system. It also seems more of a dark green than blue so trying to determine if its the correct coolant or not
