E-Class (W211) 2003-2009
2009 E550 misfire problem
Old Sep 3, 2024 | 02:34 PM
Johnnyb46's Avatar
2007 cls 550
So I keep having this problem where on the passenger side bank all four cylinders are miss firing I changed spark plugs and coil packs and still misfiring can I have jumped timing or my fuel injectors on that side are bad I’m lost right now des are the codes and I’m running straight pipe no cats or resonators or mufflers with a x pipe
Old Sep 3, 2024 | 05:53 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
missing Lambda.... misfirings
Good job with your scanner
Your misfiring issue is caused by O2/Lambda sensors not working.
Either burned fuse or old units.
Actually they have been removed so your injection is nuts.
Old Sep 3, 2024 | 06:04 PM
Johnnyb46's Avatar
2007 cls 550
so I need to put the 02 sensors back in and it shud be good
Old Sep 3, 2024 | 06:15 PM
yes, exactly 👍
You need to repair all engine "CURRENT" faults.
Old Sep 3, 2024 | 06:47 PM
Johnnyb46's Avatar
2007 cls 550
yes, exactly 👍
ok cool so ima order the o2 sensors filter adapter with the new o2 sensors
Old Sep 4, 2024 | 04:04 PM
Johnnyb46's Avatar
2007 cls 550
I
order des as well I’ll see how everything goes once they are put in
