Vibration after replacing spark plugs
Were the new plugs not fitted properly? Did he damage the ignition coil?
Am taking the car back to him on Monday but would appreciate some responses to gain a better knowledge.
PS. Before taking the car in had no such vibrations
One or more cylinder may no longer have ignition.
The coils did not die overnight but the old fragile plastic connectors may have fallen apart.
The best shortcut is to use zip-ties on all of them instead of spend many-many hours to dolice in replacements.
You can expect a dash CEL and a fault code to get logged soon.
Of course all of this extra work should be on your dime. So quick zip tie hack welcomed relief.
Buy yourself a $150 OBDII LAUNCH cReader Elite Scanner to read ALL your car - Some faults stay more quiet without CEL: no getting surprised pays-off.
Problem of vibration still there. Feel it when the car is in drive (when standstill) and in reverse (standstill). No vibration at all when in park or neutral.
Could it be anything to do with mounts?
Appreciate any input.
Besides coils two collateral issues are associated with sparkplug job:
-1- the old coil boots are best replaced with plugs. They cause misfire.
-2- the old intake seals are best replaced when disturbed. They cause vacuum leak.
As for the plastic connector plugs from the wiring harness to the ignition coils, yes, they (usually, the retaining clips) always break with age... Based on my experience, Mercedes dealerships often don't stock the connectors for these older engines anymore, and they have to order them, which takes a couple of days to get delivered. Mercedes specialist shops used to keep spares around (they're cheap), but I find that many now neglect to do that... When their techs encounter these broken connectors (whether they broke them or the connectors had been broken already), rather than inform the customer and wait around for the part to come in, they just go ahead and zip-tie them down. Conscientious shops/service managers would at least note this in the repair record/invoice and inform the customer (my shop did that in one instance). Had the shop kept the spare connectors in stock, the tech could de-pin and replace the broken one literally in seconds with the right size tool...
Since I am not into mechanics, I have forwarded all your input to the shop where the work was done.
Hope they do the needful.
Just for my knowledge, how much would a scan cost? Thanks
Trust the shop to do what they do best.
