E-Class (W211) 2003-2009
ESP Inoperative after OM642 Oil Cooler repair
Old Nov 14, 2024 | 03:54 PM
ballyroebuck's Avatar
1992 300TE
Finished up the OM642. e320 diesel oil cooler seal repair but now the car won't turn over.
Dash warning says ESP Inoperative, See Owners Manual.
I tried to read the codes with my OBD2 reader, but it responded ELM Connected, ECU would not connect.
Battery is new and fully charged.
Any suggestions on where to look to resolve the issue?
Old Nov 14, 2024 | 04:55 PM
Heguli's Avatar
2006 E280
First, throw that ELM to the bin, and get MB specific reader (Autel, iCarsoft etc., you'll find the info from here with a little search).
Second, unlike the topic title states, your real issue is engine not turning over nor starting, correct? Was your battery disconnected? If so, and you have pre-facelift car, ESP warning goes away when you turn steering wheel lock to lock, engine running.
As for engine not turning over, check your work and see if something is not connected.
Old Nov 15, 2024 | 08:41 AM
trigital's Avatar
W213 All-terrain
Without ESP the brake is not visible by the engine ECU, so it may not going to start. Check ESP connector, fuses cables brokens, etc. But also could be a divine sign to check again everything as many can happens after oil cooler repair if you clean with sharp tools...
Old Nov 15, 2024 | 09:56 AM
1992 300TE
Thanks for your advice. Could this ESP issue be related to having the battery disconnected while I changed the oil cooler seals?
Old Nov 15, 2024 | 09:57 AM
trigital's Avatar
W213 All-terrain
On the ....ESP/ABS module, engine compartment
Old Nov 19, 2024 | 06:29 PM
1992 300TE
Thanks for the previous advice.
I found fuse 57 (25A) blown and after replacement the engine will turn over, but still won't start. Looking under the hood while cranking the engine I see that when I pump the pedal the Turbo Actuator linkage isn't moving. Is there a fuse that controls the Turbo Actuator and perhaps the injectors?
Old Nov 20, 2024 | 03:39 PM
Heguli's Avatar
2006 E280
Fuse provides power to the engine control unit, which controls the various components, including the turbo actuator and injectors.
Pumping the pedal does not help to start the engine. If the engine is not running, it does not care about the input from the pedal.
Get a scanner and see what's wrong with your engine.
