E-Class (W211) 2003-2009
tools for general maintenance
Old Dec 12, 2024 | 03:10 PM
timmy0tool's Avatar
2008 S211 4MATIC
first time post now that i acquired an 08 wagon! it's my first european vehicle where i mainly come from honda/acura/toyota/lexus for nearly 30 years of driving/modifying. my question is what type of tools should i absolutely invest in when doing basic maintenance?
i normally do my own oil changes, wheel/tire rotations, filter changes, etc. and am also not afraid to get down and dirty from fluid exchanges to engine swaps - all in my home garage with no lifts or air tools.
most of my hand tools are metric but geared towards japanese makes. i've already read about different (to me) sizing like 18mm and 22mm as well as Torx. any particular sizes to have in my arsenal?
lastly, is there a budget friendly diagnostic scanner, short of the OE MB STAR?
thanks in advance!
Old Dec 12, 2024 | 05:01 PM
cetialpha5's Avatar
Well it depends what you're trying to tackle. Torx is one but then there's also external torx.
As for a scanner, a couple basic suggestions would be the Autel AP2500E if you just want a really cheap scanner that does all MB codes, around $60 on Amazon. For more advanced ones which you might not need, the Launch X431 Creader Elite 2.0 for Benz on Amazon for around $160. Lots of threads on it over at the W212 forum.
https://mbworld.org/forums/e-class-w...onal-more.html
Old Dec 12, 2024 | 07:43 PM
Œuvre's Avatar
2004 E 500 4MATIC Wagon; 2015 ML 350 4MATIC; †2003 C 240 4MATIC Wagon (2003-2022)
I recommend checking out Kent Bergsma's MercedesSource YouTube channel and website.
Old Dec 13, 2024 | 07:01 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
In addition to a decent scan tool (a must) i bought this set that gives me all the torx and etorx sockets I'll ever need for an MB.
https://amzn.asia/d/9ggeyfQ
Also, if you're doing suspension work you'll need some.open-ended spanners up to 27mm. And a decent torque Wrench. After that it's just general stuff other than a decent deep socket to remove the wheel nuts but you can still use a standard one.
Old Dec 14, 2024 | 08:13 PM
mooseman's Avatar
uh oh....
Old Dec 15, 2024 | 07:56 PM
F1Fan's Avatar
Torx, E-Torx, a long, thin walled 17mm 6 point socket for the lug bolts (i think this is the correct size). Also the security torx bits I needed for a few parts. These are the ones that has the hole in the center of the bit.
8mm socket for the small bolts (MB Part#: 0019906036) holding the under engine covers up. I would suggest getting a few replacement bolts as these tend to break or fall out. Some times the clip that the bolt attaches to falls out (MB Part#: 0019902356 or 0049943145).
As for replacement parts, I suggest using FCP Euro or ECS Tuning for OEM parts. They have a lifetime replacement warranty. So when, not if, the part fails you can have it replaced at low cost (shipping).
Enjoy learning on your newly acquired Mercedes! You will find that while it may not be the easiest to maintain compared to some Japanese brands, it is still a joy to work on. There is quality in the design and engineering of the car. If maintained properly and fed good quality parts you will be rewarded with a smooth, quiet and comfortable ride.
Old Jan 6, 2025 | 05:51 PM
timmy0tool's Avatar
2008 S211 4MATIC
thanks everyone for the input. i've been doing some research during the holidays and found lots of info as well. excited to learn more about these cars. they are very well loved worldwide, and i can see why! the philosophy from japanese to german are certainly different.
i'm going to lower the car one way or another! i'm torn to either keep the rear self leveling or change over to coil springs. the rear does sag over a few days of not driving it and replacing the bags doesn't seem overly difficult.
Old Jan 6, 2025 | 07:34 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Referring to the stickies on front page of forum. Additional info and great insight. GL.
R,
2Merks
