E-Class (W211) 2003-2009
Key fob outer case replacement
Old Feb 11, 2025 | 07:57 PM
jave808's Avatar
2007 W211 E280
Post Key fob outer case replacement
Hi
I just received 2 replacement key fob casing for my 2 button cell battery key fob. I've included the link from the AliExpress dealer that I bought them from.
Changing over the PCB is easy. Remove the battery holder from the original fob. Then pull out the PCB just below the lock/unlock buttons. Use a set of needle nose pliers.
Now insert the PCB into the new key fob casing. Then move the 2 batteries across into the new battery holder, then insert the battery holder into the new key fob. Test. Everything should work!!!
Link: https://www.aliexpress.com/item/1005...tml#nav-review
Original case on left. New case on right.
Old Feb 18, 2025 | 03:40 AM
jave808's Avatar
2007 W211 E280
test
Old Feb 18, 2025 | 08:03 AM
W205C43PFL's Avatar
Originally Posted by jave808
Hi
Mb logo is missing or darken out?
Old Feb 18, 2025 | 04:16 PM
jave808's Avatar
2007 W211 E280
You can't see it well in the photo but there is a small piece of plastic that comes with the new case where the MB logo is on the original key case. That piece of plastic doesn't have the MB logo. You could possibly remove the MB logo from the original case and stick it on the replacement case.
Old Feb 18, 2025 | 06:03 PM
W205C43PFL's Avatar
Ah gotcha the mb logo is a extra cost option basically or not offered. : )
Old May 17, 2025 | 12:52 AM
MacVidMB-V8's Avatar
W209, W124
Does it have holes where the logo would attach?
Great idea anyway, I have repaired many of the Gen 2 SmartKeys when they got wet with cracked buttons. Wet finger wicks rain/coffee/beer inside too well.
