E-Class (W211) 2003-2009
E350 2007 - transmission or conducter plate issue
Old Mar 18, 2025 | 03:52 PM
phirichey's Avatar
Mercedes E350 2007
1st time on here- my vehicle runs fine as long as i stay under 50 mph- if i go over it drops out of gear- 20-30 sec & it starts back up again- runs fine- frustrated- any ideas ????
Old Mar 19, 2025 | 02:16 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W211 forum...
Old Mar 19, 2025 | 02:51 AM
beef1020's Avatar
w164 ml350
Did you scan the transmission module for codes? The 722.9 has a lot of common speed sensor issues that require either a new conductor plate or repair.
Old Mar 19, 2025 | 08:19 PM
timmy0tool's Avatar
2008 S211 4MATIC
it sounds like the trans went into limp mode (or go home mode), and a restart can clear it albeit temporarily. the issue will come back where you're stuck in 2nd gear only plus reverse.
i had the same symptoms on my 08 recently. a scan saw speed sensor 3 is faulty pointing to the conductor plate. you will need to scan yourself to find out for certain.
