E-Class (W211) 2003-2009
HELP PLEASE
Old May 21, 2025 | 08:52 PM
06E350Merzzz's Avatar
06 E350 Base sedan
HELP PLEASE
2006 E350 BASE RWD
replaced eis. key in and turns. throttle body makes noise.
No mileagle on gauges and no crank.
i believe pin 2 on plug c is no voltage. i just need help finding the fuse that covers it
thabnk you
Old May 22, 2025 | 11:17 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
BETTER TROUBLESHOOTING STEPS
forget fuses going bad for low-power modules...
You need to use a $150 MB scanner to read module conditions from OBD2 connector.
Realise that parts can not be interchanged without coding them to your chassis.
Old May 22, 2025 | 04:16 PM
06 E350 Base sedan
the key locks and unlocks the doros and turns in the igniton. I get dash lights but no crank and with my icarsoft mbv3.0 hooked up[ it does not reads the vin. I used my test light to check the voltage on plug c and found pin 2 to be 4 volts instead of 12. I do know that is circuit 15.
Unfortunately i have a health issue that limits my ability to work at times so i cpouldnt pursue the matter yesterday
Old May 23, 2025 | 05:14 PM
NO-CRANK DRIVE AUTHORIZATION
I wouldn't deal with pin-voltage knowing you've swapped a security module. You're literally dealing with a network of computers on wheels
Does your scanner read data out of EIS ignition Key slot? Not just fault codes but PID values.
You want to make sure ignition security is not vetoing start authorization.
Old May 26, 2025 | 07:00 PM
MacVidMB-V8's Avatar
W209, W124
You need to feed us the details so we can avoid asking entry level questions.
What got replaced WITH the EIS? (ie, keys, ECU, TCM, etc)Or did you clone old info onto new?
What precipitated EIS swap? Obviously, if it was this same exact issue, we need to know.
Old May 31, 2025 | 09:16 AM
06 E350 Base sedan
i need the pin voltage. because my i carsoft is not readring the ecu
Old May 31, 2025 | 10:42 AM
going around circles
Pin voltage is a waste of time.
You need to diagnose this at network level, not pin level.
Perhaps is not getting any power at all....
Old May 31, 2025 | 10:52 AM
06 E350 Base sedan
Replaced EIS with new. Key info cloned from old EIS. due to mine damaged by ebay vendor.
Provider of replacement EIS used different part Number EIS,
OEM 211 545 23 08
NEW 211 545 23 18
after i asked him not to.
HE SAID PART NUMBER MAY BE DIFFERENT BUT THE BOARD IS THE SAME. I DO THIS ALL THE TIME.
REPLACED OEM battery with H8 AGM bateery due to mine being dead.
This is what happens:
Lock/ unlock with remote.
Key in gets door xing and dummy lights.
turn key gets green light on emulator, all dash lichts anf throttle flaps zound off.
gauges are funtional except NO mileage.
Instead ut shows. ------------
I have iCARSOFT MBV 3.0
It powers up but wont read vin or con ect wkth ecu
Old May 31, 2025 | 07:25 PM
That description is helpful, thank you.
Scanner should connect to chassis regardless of drive authorization pass/fail status - Chassis already partially powers up from keyfob, a good sign.
Your scanner staying mute... suggest a bad SAM fuse... or scanner is unable to read your particular chassis VIN. So go ahead, enter VIN manually to progress past that step. Scanner will enumarate active modules then you can interact with car network.
Old Jun 1, 2025 | 04:39 AM
06 E350 Base sedan
i did exactly that and it stayed scanning transmission control module fkr 10 minutes.
i cycle d the key off, restarted the i ceasoft, selected OBD, Device said it co I ld not link to vehicle
Old Jun 1, 2025 | 08:32 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
@06E350Merzzz
Bars on the instrument cluster odometer indicate a VIN mismatch in the modules. Was the replacement EIS programmed with your vehicle's VIN? Motor Electronics, steering column lock, Electronic Ignition Switch, and Instrument Cluster must have matching VIN number in the modules. If only the instrument cluster is mismatched, the vehicle will start and run but the odometer shows bars to indicate it is not programmed to the vehicle. A VIN mismatch in the other three modules will prevent a start authorization. You need a diagnostic tool that shows the status of start authorization.
@CaliBenzDriver see attachment for some good tech info on the various drive authorization systems.
File Type: pdf
Old Jun 1, 2025 | 02:14 PM
DRIVE AUTH FAILS
Originally Posted by bbirdwell
@06E350Merzzz
@bbirdwell
what steps do you think OP should take?
I find it odd scanner fails to connect... does iCarsoft V3 know to support this model year??
Scanner gets stuck on TCU not answering network: SAM does not enable IGN power ON du to DAS failing VIN
TCU needs IGN:ON (ENG:OFF) to get powered up.
Old Jun 1, 2025 | 09:25 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
@CaliBenzDriver @06E350Merzzz
-OBD2 Breakout box. Check all pins of the OBD2 connector using the breakout box.
-Verify CANBUS voltages using the breakout box.
-Verify CANBUS voltages at the CANBUS-C connector on the driver's side frame rail.
-Connect CANBUS Analyzer to the CANBUS; first in the breakout box, then in the CANBUS-C connector for the motor electronics. See link below. It was a TCU module killing the CANBUS start signal.
-Attempt a different diagnostic system and verify latest software. On my C4 system, I had outdated drivers; updating them corrected the connectivity issue that was driving me nuts.
I agree with Cali that the issue is likely a networking issue. Following the above will confirm if it is a network or electrical (broken or shorted wire or integrated circuit chip) issue.
See this:
https://mbworld.org/forums/w211-amg/...-no-start.html
Query: Was the EIS programmed to your car or was it just "Trust me"? FWIW, if you are installing a virginized Motor Electronics Module (ME), you must use STAR/Xentry to "marry" the module to the car. Might be the same for the EIS but I cannot say for sure as I have never installed a replacement EIS; only a replacement ME module.
Download WIS schematics here:
https://charm.li/Mercedes%20Benz/
I recommend downloading and installing an aftermarket downloader. Windows11 choked at 1.0GB on my computer and the W211 file I needed was 1.21GB. Took me two or three attempts to figure out it was Microsoft bending me over again...
Please let us know the solution for future owners.
