E-Class (W211) 2003-2009
New to the forum
Old May 25, 2025 | 09:56 PM
Snuggs's Avatar
New to the forum
Name is Donnie Snuggs and I just recently purchased a 2007 Mercedes Benz e350. Didn’t know much about the car but it was a daily driver from the guy I bought it from. I bought it for cheap because the old owner was told by a mechanic shop that it needed a new engine. I can get the car to start and run for about a second or 2 bucks then it dies and won’t start again until I change out the burnt fuse which is fuse 43. I volt rated the fuse after it blew got 12 volts on the power side and 1.5 on the other side which should not of had any voltage. I would greatly appreciate any insight on this issue. This is going to be my youngest daughter’s first car. Thank you all for any help I might get
Old May 25, 2025 | 10:43 PM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a photo of the MB.
Old May 27, 2025 | 02:38 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W211 forum...
Old May 27, 2025 | 11:41 AM
Heguli's Avatar
2006 E280
Very useful tool that you will need is a MB specific scanner (Autel, iCarsoft, there a lots of info about them in here).
That fuse is for engine control unit. Might be faulty unit, or wiring issue.
Old May 27, 2025 | 05:54 PM
timmy0tool's Avatar
2008 S211 4MATIC
i would start with a scan to see any glaring issues.
also could be the camshaft sensor:
(post #12) https://mbworld.org/forums/w211-amg/...s-burning.html
(post #13) https://mbworld.org/forums/e-class-w...p0560-obd.html
Old May 28, 2025 | 04:11 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
@Snuggs
https://fuse-box.info/mercedes-benz/...uses-and-relay
Fuse 43 powers the ME (Motor Electronics). Disconnect ME module and see if you have a short to chassis on that line. If it is a bad ME, you'll need to source a replacement. That will require either the PROM from your ME transferred into another "re-virginized" ME or the replacement ME being programmed with your vehicle VIN. If replacement is required, you will need STAR/Xentry to "marry" the replacement ME to your vehicle. I've only done this once; not difficult but slightly stressful.
For your sake, I hope it is just a short in the power line and not a problem in the motor electronics.
