E-Class (W211) 2003-2009
ESP module swap with or without coding?
Old Jun 8, 2025 | 03:56 PM
Gripen's Avatar
2004 Mercedes E55 AMG Wagon
Hi All,
I have a bit of a stiff steering issue (since I've owned the car in 2021) for which I basically replaced everything (twice) apart from steering rack and ESP module. My wife doesn't want to drive the car because of it...
If I enter the ESP module with diagnostics tools when the car is on the steering stops being stiff and feels light so I want to see if swapping out the ESP module fixes the issue.
I found out this is my ESP module code from EPC: A0335454032
Do these need to get coded to the car or can I just swap and see what happens?
(It's a 2004 E55 AMG Wagon btw.)
Old Jun 11, 2025 | 09:42 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Originally Posted by Gripen
Hi All,
Yes, indeed coded big time. Dont mess with it just now unless you have too.
ESP deals with brakes calipers, not the steering rack.
What issue are you trying to resolve:
steering or brakes or suspension or electrical ....?
Old Jun 12, 2025 | 02:58 AM
Gripen's Avatar
As far as I'm aware the ESP module does deal with the valve in the steering rack that decides how stiff the steering is. The ESP module looks at the wheel speed sensors etc. and then operates the valve?
When I start my car and drive away my steering is relatively easy (deffo not as easy as my 2007 BMW 530i Touring) but when I'm at the end of the street and turn the corner it's already stiffer and it stays very stiff. It's VERY annoying if I go over a roundabout.
I've changed the valve in the steering rack 2x I've replaced the power steering pump 2x I've replaced the reservoir 2x. I've done the bleeding about 9 million times.
With my DAS (Tactrix Openport 2.0) I can't access the SBC and EPS module, for the rest I can access all. With my Foxwell NT530 (Mercedes edition) I can access both.
The funny thing is, when I access the EPS module with my Foxwell NT530 you get the EPS/ABS warning in the screen, I think this is normal and then the steering is completely easy as it should be. It's a pleasure to drive the car all of a sudden if I leave the Foxwell 530 hooked up to the car and ESP module. It's like it's a different car.
That's why I think (don't know for sure of course) there must be something wrong with the ESP module if accessing it DOES make the steering very easy (not stiff).
We used to have a lot of W211/S211 taxi's here and I always see these taxi drivers steering them with one hand or a finger so I can't imagine mine is as it should be.
Old Jun 12, 2025 | 02:06 PM
YOU GOT IT
Thank you, now I understand your ESP issue. You have done precise troubleshooting to pin-point: ESP has developed poor internal connections.
You want reliable steering + brakes!
A used unit would be nearly as bad.
A new unit... good luck with that.
A refurbished unit would need coding.
Repairing your own unit is best: better than new, no coding!
I have repaired W212 ESP, not exactly W211 and know Bosch builds them with pressed pins that benefit good soldered connections to work well.
ESP Module showing internals
nearly reliable pressed pins
The control solenoid inside your steering pump acts like an electric coil with current surges that oxidize poor ESP connections.
The key to dealing with ESP/ABS Module is it must be reliable for brakes to perform as desired.
I am not advocating you begin repairing your own electronics... just that ESP needs a quick soldering job.
Online professional shops routinely perform this refurb service. I do not.
Couple other modules use similar pins setup. "Key slot" is one.
Old Jun 12, 2025 | 02:19 PM
Gripen's Avatar
Thanks CaliBenzDriver and totally agreed I want reliable steering and brakes
I might actually send it out to a shop that does repair these units or can fix them as you say however I have ordered two second hand units and they are on their way to my house, will probably get them tomorrow. One is a refurbished unit and another is a second hand unit. Both from E55's, no idea if it will change anything but I thought I'd just try it anyway
Will update once I have received and tried them!
Old Jun 12, 2025 | 04:08 PM
that's a solid plan !
You'll have parts inventory.
Let's have a look.
Old Jun 16, 2025 | 02:23 PM
Gripen's Avatar
I received one of the two ESP+PML modules and just installed it.
First off, there is no issue running this module so I don't think a W211/S211 ESP+PML module needs any coding, for anyone that is interested in that.
Then the results: It seems like the module has fixed my problem!!! Steering is now light / much lighter.
I'll drive it to work and back tomorrow to verify, not that it's placebo effect buit it genuinly seems fixed so far! Very happy
Old Jun 19, 2025 | 11:21 PM
How was your power-steering like during your test drive ??
Old Jun 20, 2025 | 07:54 AM
Gripen's Avatar
I've done two trips in the car and it's so much lighter!
- Roundabouts
- Turning from standstill
- Turning while slow rolling
Additionally I went into the ESP module with my diagnostic tool (Foxwell NT530) and saw some stored codes that I think were of the old car. I removed them and they didn't come back. I also did the "road test" which went fine. Almost felt even lighter after that but that's probably placebo effect
Very happy I made the purchase and tried this. This did solve my problem
