2008 E350 PZEV gas smell (W211)
My 2008 RWD smells of gas after filling gas. I read through the forum and was able to look under the rear seat (driver's side) and saw a pool of gasoline (may be less than 1/2 ounce) over the cover in the backside (may be because it's sloping down rearward). I cleaned it and put the seat back. I don't see any crack. Also, the cover is black (not white as other posts). The more I read the posts, the more confusing it gets.
Please let me know if it can be fixed. If so, what are the parts needed. Sorry, I forgot to take pictures when I removed it. I can take the picture if needed.
Thanks in advance.
PS: This is my first post and I'm fairly new to navigating this site, so please be kind to me. Also, when I entered my VIN in lastVIN, I see that mine is PZEV (New York car when new)
Can someone please tell me what do I need to do to address this issue (and if I cannot, what needs to be done to fix this issue). Thank you.
Since I just got it, I am trying to avoid spending too much. Thank you.
Given that the fuel pump might have been changed (and the mechanic is going to do a better patch of the passenger side), is there anything I can do to the gas leak on the passenger side? Whatever part is available (on RockAuto) is for non-PZEV.
Any help is greatly appreciated.
PS: Can aused tank (non-pzev) replace the current one?
