E-Class (W211) 2003-2009
Random Shutdown Behavior
Old Yesterday | 01:12 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
totally clean failure
Originally Posted by namalik
Actually, the Mercedes DAS/Xentry software (where this report originated) will NOT put a check mark if there are any faults. You will see an "ï", or "f" or "F" and then you can dig down to determine the real fault/code including any stored ones. There are no fault codes on this chassis. Ah well, back to the drawing board.
If we summarize you're dealing with a random shutdown that leaves absolutely ZERO FAULT live or stored.
It must be high up the power supply tree like the main relay itself.
not the ALT
not the Battery
not the main GND.
If a branch was getting powered down, the other modules would log faults on missing partners.
Absolutely nothing gets logged on any network. No fault ie. better than factory new.
FYI: older faults should be recorded as either active or stored.
Old Today | 01:29 AM
namalik's Avatar
2006 E200 Kompressor
not the ALT
not the Battery
not the main GND.
"It must be high up the power supply tree like the main relay itself" - Very useful observation!
BTW, all stored or active faults can be cleared by the DAS/Xentry software leaving no record. If you see the thread, the car did throw some wiper related codes some time ago, but they were cleared at that time. What you are seeing now is the current state of the car which has not thrown any codes since, maybe, the last six months or more.
Old Today | 11:05 AM
Post few available hints
Don't just wait for Xentry to hand you a fix with a DTC Code.
Try to get a leg up on what crashes your whole system so quietly : prefuse + SAM.
Bumper radar harnesses can do a number on engine ECU shutdown/start if so equipped.
You don't have manu hints available...
### beautiful S-class near downtown HK Island
Attached Thumbnails Random Shutdown Behavior-screenshot_20260603_170650_gallery.jpg
