Sponsored by: CARiD
Bulletins 207 coupe & 212 sedan
Old Jun 4, 2014 | 12:04 PM
  #201
konigstiger's Avatar
'71 Pinto
Originally Posted by /// M
Does anyone have access to tsb for this one? Even though my ecu is stil tuned, the added power is lost after this service. I need to know what exactly was done. Thanks
Procedure:
DAS/Xentry 09-10/13 with add-on 3153 or higher.
Connect battery charger (battery voltage >12.5V).
Ensure all electrical consumers are switched-off.
In the event of software/SCN update issues, contact Star Diagnosis User Help Desk.
Update fuel system control module software (FSCU):
DAS: Control units / Drive / FSCU / Control unit adaptations / Control unit programming.
Xentry: Control unit view / Drive type / FSCU / Fuel pump / Adaptations / Control unit programming.
Verify fuel system control module software number change after performing the software update.
Old Jun 4, 2014 | 05:09 PM
  #202
/// M's Avatar
Merc
Procedure:
Much appriciated. Thanks
Old Jun 9, 2014 | 03:44 PM
  #203
'71 Pinto
LI65.00-P-059054 MAY14 – 2014 207.4xx AIRCAP functions excessively activated wind screen at rear seat extends, 25 mph or higher windshield wind deflector extends, speeds below 9 mph retracts automatically. MY13 both wind screen and front deflector remain raised until deactivated or vehicle is turned off. Dealer will/can revert function to MY13.
LI.85-P-059083 MAY14 – (NTG 4.5) 207,212,218 code 088, 803 or 804; 204 code 802; 166,117172,176,204,231,246 code 803 or 804; 463 code XZ2/3 sporadic failures of Audio/COMAND display unit. Check: for fault codes; connections; cable set chafe marks/crushing; software update if none rectify the complaint create PTSS case.
LI54.65-P-059114 MAY14 – 212 code 501 produced up to 7/14; 222 code 501 up to 5/20/14; 166 code 501 up to 7/14 at night picture from camera in display on head unit can appear too dark, software update with optimized parameters is available.
Service Campaign 2014050002 JUN14 – 2014 212 & 218 transmission control module (TCM) does not correspond to current product configuration low transmission oil temperatures combined with certain driving patterns may affect engine running characteristics, dealer will update TCM software. Approximately 640 vehicles affected.
Old Jul 7, 2014 | 03:01 PM
  #204
'71 Pinto
LI72.40-P-059215 JUN14 – 212, 207, 204.2/3/9 (code 237/804+054) active blind spot assist intermittently inoperative. Front door control units sporadically detect false short circuit, flash left & right DCUs.
LI54.21-P-059247 JUN14 – AMG 212.074/75/76/92; 218.374/76/92; 463.272/273 no double-clutching function (exhaust system sound) in transmission mode S & M, update engine control unit software.
LI49.20-P-059246 JUN14 – 117, 176, 204, 212, 207, 218, 172, 246, 166, 221 with 651 engine. CEL – stored fault codes P245997, 246397, 245900, 246385 or 246309 follow guided tests in XENTRY, which have to be fully processed.
Old Jul 9, 2014 | 03:50 PM
  #205
EPOWELLIV's Avatar
C63 AMG
WE HAVE A E63S 4MATIC WITH A WHISTLING NOISE WITH WINDOWS UP @ 67-75 MPH AND THEY FILLED THE GRILL IN WITH MORE MOLDING AND FILLER BUT IT IS STILL THERE, ANY HELP THE LAST OF THE VIN IS EA973872
THANKS
EDDIE
Old Jul 9, 2014 | 03:56 PM
  #206
EPOWELLIV's Avatar
C63 AMG
AND IT IS WORSE WHEN IT JUST GOT WASHED OR RAINING
Old Jul 13, 2014 | 02:12 PM
  #207
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
Stand alone thread
THANKS
EDDIE
You might want to post this as a stand alone thread.
Old Jul 30, 2014 | 03:36 PM
  #208
Vector's Avatar
2011 W212 4matic
Here is a list of W212 TSB's: https://www.eautorepair.net/app/TSBS...tic&PS=2&MA=15
Old Aug 11, 2014 | 04:13 PM
  #209
'71 Pinto
Service Campaign 2014030001 JUL14 - MY13-14 212 Hybrid update transmission control module software. Approximately 342 vehicles affected have dealer check Vehicle Master Inquiry (VMI) to see if VIN is included.
Old Aug 28, 2014 | 11:21 AM
  #210
'71 Pinto
delete
Old Sep 9, 2014 | 05:19 PM
  #211
sigx5's Avatar
2014 E350
delete
Hi konigstiger,
Any new update? Thanks.
Old Sep 9, 2014 | 05:27 PM
  #212
'71 Pinto
To date a few released for 222, one for 221 but nothing for 212.
Old Sep 9, 2014 | 05:31 PM
  #213
sigx5's Avatar
2014 E350
Old Oct 7, 2014 | 03:53 PM
  #214
'71 Pinto
LI25.00-P-059830 SEPT14 – Wet Clutch AMG vehicles with Eco Start/Stop & VGS4 jolting on start off after engine Eco restart, update engine control unit (ECU) & transmission control unit (TCU) software + perform wet clutch adaption.
LI82.10-P-059909 SEPT14 – 207, 212 with full LED headlamps (640) as of 2014 noise from headlamp area with vehicle parked and ignition off. Headlamp cooling fans may run for an extended duration due to latent engine heat or other ambient temperature related factors. If headlamps are fully functional and no fault codes are found this is considered normal.
LI46.35-P-059842 SEPT14 – 204, 207, 212 with direct steering (211) except 4matic, warning message “Power Steering Malfunction – See Owner’s Manual” and steering assistance is reduced if 2129017404 is installed update ES control unit software any other number create PTSS case for MB assistance.
Old Oct 14, 2014 | 02:57 PM
  #215
Hellbruegge's Avatar
E 63 AMG 2010
E 63 A MG 2010 - M 156 engine
Are you familiar with Technical Service Bulletin LI01.30-P-051567 from Arpril 14, 2011?
What action would you recommend?
Thanks for your help and great forum on the W 212
Ricardo Hellbrügge
Old Nov 4, 2014 | 12:50 PM
  #216
'71 Pinto
Service Campaign 2014010001 OCT14 – 212 Hybrid starter may not reach the internally required number of starting procedures. In such case, the stop-start function would no longer be available. During the required maintenance service (every 10,000 miles) starter counter is noted. Xentry will indicate the need to replace the starter and ring gear when specified values have been exceeded. Approximately 494 vehicles affected. Have dealer check Vehicle Master Inquiry (VMI) to see if VIN is included.
LI82.70-P-060004 OCT14 – iPhone exhibits various faults after updating to iOS8 and/or Bluetooth connection between iPhone & COMAND is disrupted, under analysis by Apple perform software update when newer version is available.
LI82-P-060002 OCT14 – Digital DriveStyle app does not lunch automatically, iOS8 software from Apple does not support automatic launching - manually launch after connecting with Drive Kit Plus.
LI54.10-P-060034 OCT14 – 212 hybrid (code ME04) vehicle cannot be unlocked, engine does not start, silent-start inoperative replace power electronics/distributor & starter battery.
Old Dec 3, 2014 | 03:35 PM
  #217
'71 Pinto
LI91.29-P-059833 204, X204, 207, 212, 218 with option code 275/memory package (may also have 242/ RH seat w/memory) seat/column non-functional on startup when vehicle sits for a long time, change power supply circuit from ckt 30g to ckt 30.
Old Dec 30, 2014 | 12:45 AM
  #218
turbonos7's Avatar
'05 S430, '05 S600
Service Campaign E250BT
We just had it done, my wife misplaced the paperwork so I don't have the campaign number but it is for the MY14 with the 2.1 liter engine. Timing chain tensioner seal ring needs to be replaced due to leakage. I will try to find it and post it on here. Just wanted to get the word out. Happy New Year everyone!
Old Jan 5, 2015 | 01:26 PM
  #219
'71 Pinto
Service Campaign 2014110004 DEC14 2015 212, 207, 166, X166, 172, 204, 231 COMAND control module software customer may not be able to change channels during SDARS reception display shows “Updating Channels”, dealer will update software. Approximately 30,157 vehicle affected. Have dealer confirm if VIN is included – MBUSA can also check here http://www.mbusa.com/mercedes/recall
Recall 2014120002 DEC14 2014-2015 212, 204.9 (GLK) & 2015 166 (ML) w/651 engine (4 cylinder diesel) chain tensioner sealing ring may exhibit increased settling behavior which could negatively influence pre-tensioning force, dealer will replace sealing ring. Approximately 4,314 vehicle affected. Owners of affected vehicles will receive a letter. Have dealer confirm if VIN is included, MBUSA can also check here http://www.mbusa.com/mercedes/recall
LI54.10-P-060515 DEC14 212, 207, 218 (B03) ECO start/start inoperative + message “Battery – Service Required” FC B21DF71 displayed, incorrect installation of accessories. Approved accessories must always be connected directly to ground points provided on the body in accordance with installation instructions. Work will not be invoiced under warranty or goodwill.
LI83.10-P-060403 DEC14 212, 204 w/code 581 noises from rear blower motor, check to see if cable set is properly installed.
Old Jan 15, 2015 | 09:35 AM
  #220
hiddenagenda's Avatar
2011 W212
WDDHF4HB7BA490616
Can someone give me the bulletins on this ? Specofivially I'd there was any camshaft or solenoid recall or problems .
Old Feb 3, 2015 | 03:07 PM
  #221
'71 Pinto
Recall 2014120006 JAN15 – 2015 212 in the event of severe frontal crash for the rear middle passenger seat, double seat belt buckle may fail. Dealer will replace buckle. Approximately 1,378 vehicles affected.
LI91.10-P-060560 JAN15 –212 front seat belt buckle rubs on leather causing creaking noise, buckles must be lined with felt.
LI72.40-P-060689 JAN15 – 207 window operation nonfunctional, software error adjust parameters to door control unit.
Old Feb 3, 2015 | 03:18 PM
  #222
'71 Pinto
Originally Posted by hiddenagenda
WDDHF4HB7BA490616 Can someone give me the bulletins on this ? Specofivially I'd there was any camshaft or solenoid recall or problems .
Service Campaign 2012070002 may apply
https://mbworld.org/forums/e-class-w...ml#post5381790
In addition, and although not covered by campaign solenoid installed at production is replaced.
File Type: pdf
File Type: pdf
Old Feb 3, 2015 | 03:50 PM
  #223
MBSebas87's Avatar
C300 Sport 4Matic
any bullintins or recalls for mine? VIN -WDDHF8JB7CA629968
Old Feb 3, 2015 | 08:07 PM
  #224
DerekACS's Avatar
2015 E250 BT 4M
Any idea of the VIN range for this W212 recall ?
Old Feb 4, 2015 | 11:28 AM
  #225
'71 Pinto
Only documents model year, have dealer check VMI to see if your VIN is included.
For MBUSA members you can check here http://www.mbusa.com/mercedes/recall
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
