Sponsored by: CARiD
HOLD function
Old Nov 3, 2009 | 05:29 PM
dmikim's Avatar
E350W
HOLD function
Hi Everybody!
I got my E350 yesterday, and I found the HOLD function description in the manual, unfortunately I couldn't activate it today.
Does anyone know if "HOLD" function is a part of "distronic plus" or this just a standard function? If it is a standard what should I do to activate it?
Thank you!
Dmitriy Kim
Proud owner of E350W
Old Nov 3, 2009 | 07:35 PM
MOZART's Avatar
2004 E500
I've tried it too and it didn't work. I even asked my salesperson about it, and needles to say he had no clue what I was talking about.
Old Nov 3, 2009 | 08:19 PM
AJRDU's Avatar
E550 Coupe
Come to a complete stop as normal with normal brake pedal pressure. without taking your foot of the pedal, press it down harder. you'll need to press it down with a swift firm motion. Don't try to slowly increase the pressure. Mine works very well and I use it all the time. (W207 coupe)
Old Nov 3, 2009 | 08:28 PM
dmikim's Avatar
E350W
Thanks a lot, I'll try it this way.
Old Nov 4, 2009 | 01:11 AM
Diesel Benz's Avatar
Originally Posted by dmikim
Hi Everybody!
It isn't any Distronic related feature. I had this already on a late 2003 European W211. It used to be disabled from US cars but I've understood it would be included with W212 and C207 (probably some other models too).
Works like described in a previous post above.
Old Nov 5, 2009 | 08:13 AM
Steel.Grey.MB's Avatar
2010 E550
Tried it out and it works really great. But I don't know if I feel comfortable relying on it....I kinda like my foot on the brake pedal. Security thing IMO.
Old Nov 9, 2009 | 12:08 PM
2010 E550's Avatar
2010 E550 Iridium Silver ; black int; burl walnut; rear & roof spoilers
"hold" brake function
like the others say......once stopped press hard on brake pedal once & it should be activated......to release do the same....it works great on hills....uphill or downhill ........
Old Nov 9, 2009 | 03:30 PM
You can release it also by simply pressing the gas pedal. At my 221 I can also use the cruise control lever, I guess it must be the same with the 212 (I admit I don't remember how it works with the 212 without Distronic Plus).
Old Nov 20, 2009 | 02:47 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
sweet... i'll dig up SDS and see if i can enable it...
Old Nov 25, 2009 | 04:26 AM
urceyes's Avatar
2010 E350 sport sedan
No, It's not part of the distronic plus function as i dont have it on mine but still able to use the HOLD function.
Well ...... I had the same feeling as yours at the beginning but now i use it all the time. Great function ~!
Old Nov 25, 2009 | 10:13 AM
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
Hill Holder?
Is this what they used to call a hill holder for the brake? Got my E this past week-end and it does have a hill holder. Read the manual, but it is not real clear to me.
One thing I noticed was that if you use automatic car wash that pulls the car through, you have to turn off the Hold by pressing accelerator. Is this really true? I'm sure the guys in the places I use are going to drive it up to the end, stop it, put it in neutral and get out.
Thanks,
Old Nov 25, 2009 | 12:16 PM
dmikim's Avatar
E350W
I think the hill holder is not the same as HOLD function. Hill holder comes with distronic plus.If you use automatic wash you just need to shift to "N". If you had HOLD pressed than you have to deactivate it (I think it will automatically go off whern you will shift to "N")
Old Nov 25, 2009 | 03:00 PM
highroller550's Avatar
2010 e550 coupe , 2010 ML550
i dont see the point of it. when will you really use it. why not just put the car in park.
Old Nov 25, 2009 | 03:54 PM
Rowrbazzle's Avatar
2010 E350
It's the same effect, but you don't have to shift in and out of park each time you stop (admittedly, that's only a push of a button in this car). Just put on the brake and go all the way down, then when the light turns green hit the gas and go. I've actually found myself using the feature very frequently.
Old Nov 25, 2009 | 05:38 PM
well im going to try it, i still think its pointless.
Old Nov 25, 2009 | 06:07 PM
emilner's Avatar
S560
It is one of the best features! Its great coming to a stop and being able to keep the car stopped w/o having to shift into park. It's really great when your tired and you want to relax your leg for a minute...
Old Nov 25, 2009 | 06:40 PM
451/443=EW's Avatar
C350 4Matic
I think some guys are confused here. The HOLD function is not ment to replace putting your car into park. It is ment for use on hills while waiting for a green light so you dont have to keep you foot on the break. You can simply relax and when the light turns green just hit the gas and go! So all this talk of putting your car in park has me I hope you guys dont put you car into park while waiting for lights to change.
Old Nov 26, 2009 | 12:51 AM
pmb600's Avatar
E550 4MATIC
The first times that I tried the HOLD function I had trouble getting it to work myself. The only thing I can say is keep trying it until you get it. Once you get it to work, you will be asking yourself how you didn't get it all along.
Old Nov 26, 2009 | 06:39 PM
HB230's Avatar
C230 Sedan, W212 E550
I also noticed the brake light stays on while the car is in HOLD. Much safer than putting the car in park.
